Hi @mvvRAZ ,
Thank you for your thread. It's the only pragmatic IEM thread I can resonate with...
^^ From Nic's thread, not sure if you remember I...
Anyways, I ended up switching to IPX sockets because my 2-pin sockets fell out. What a relief. I don't have to worry about reverse polarity .75mm extruded sockets anymore.
I'll be researching the A18s on this thread.
I think the loosening will only occur if you cable roll a lot - the different sockets are technically good for "X" insertions, and 2pin tends to have relatively fewer insertions compared to stuff like IPX. All in all though, with any IEM and any regular usage, you should be fine for years before you start encountering socket issues (as long as everything is up to spec once again)
