Also, my Amazon cable glows blue
I'm jealous, I've only getting one of these
http://www.ebay.com.au/itm/360845725161?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648
it's great! Can you upload more photos!I'd like to propose a different tape bass mod than the popular one where you remove the sticker over the port. I took some gaffer's (duct) tape and ran a winding around the ear cups. It's not nearly as obvious as removing the stickers on the bass ports was, but it pulls up the bass and sub-bass (and impact) without ruining the awesome sound stage and making low vocals sound goofy, like the port mod. I tried the port mod a couple times and opted against it, this mod doesn't seem to have any down sides and it even looks good. Take off the velour ear cup and wind the tape so it's as far below the lip as you see in the photo, and cut the excess tape off the back before clipping the cup back on. Easy, might as well try it!
Try something like http://www.youtube.com/watch?v=upsobBEJxXw ----- Erase by Beats Antique to hear exactly what it does.
I have the Chinese version. It has soft bumps and a tight fit on my head. I don't think that AKG has messed up with sound. And my q's had tapes on each earcup.so I think the difference is with the "BUMPS".Which of you have the Austrian-made model and which of you have the Chinese-made? Can anyone tell any differences?
How are you liking your Bifrost?
I want to ask that the Austrian made and China made, which is better? Where to buy the Austrian made, im living in US.
And is it good for all-rounders?
Tks
Tks
I believe it's all down to luck. If you want to make sure they are from Austria, go to a retail store and either look at them, or purchase them and make sure it is what you want.
I can't say either one is better or worse. Though I will say that "Made in China" being bad is just a bunch of schitt. After all, where are all the shiny pretty iPhones made?
So iPhones are Made In Austria?
