Getting closer to my desired small footprint for on the go, come next pay check I may reach my portable nirvana!
- Thread starter RingingEars
Toulouse
- Aug 15, 2016
@boblauer
Is there any specific reason why you are using your earbuds with the X3 II and E6 instead of with the X3 II on its own?
mpawluk91
- Jan 1, 2013
I was wondering the same thing@boblauer
@HiFiChris
For those buds no, the RX1 are only 16 ohms. I have other higher impedance ones(320/400 ohms) that the amp helps out.
My main goal is to get my travel /portable package down to one small set of items regardless of what earbuds or IEM's I am using for the day. That's why I resurrected the E06 and am going to use a Benjie K9 as the DAP for that. I haul way too much stuff with me for work.
What will your next purchase be?
@Toulouse
Benjie K9 as a DAP. Trying to get everything into a light compact package and under $100 for work and travel. I lost a Plenue D in June overboard when helping a friend move a 88 foot sailboat from Panama to New Zealand and decided then I need to pair down what I use so I don't stress over losing things which I seem to do a lot.
Podster
@Toulouse
I hear ya Bob, this is my new small in stature big in sound setup
Shuffy w/AP001 and Vyrus
@Podster
My original thought was to use a 2gb shuffle but can't find the charger. So going with the Benjie.
I have Vyrus as well but confining myself to ear buds on the go for a cheaper replacable solution should I or when I lose something. Love the Vyrus use them at home a lot. I have a small amazon basics case with the DAP, phones, amp and cables. Once Benjie gets here I'll post it up.
singleended58
- Dec 29, 2004
I made this IC cable myself a few years ago, including a few others whereof some can can seen in the picture above that was taken about at the same time as when I soldered them.
As you can also see in my stacking pic, that particular IC cable doesn't look as nice as it once did, as I am using it quite often.
I am using with my DYI IC would help the sound has more weight and more smooth details. Listening with IE800.
Mimouille
I wouldn't have bet on it , but this works well.
- Sep 25, 2010
Cheapo entry level ^^
Me iz jealous!
FFBookman
- Jan 8, 2015
I SEE YOU, GEORGE!
Mimouille
It is missing something I wonder whatCheapo entry level ^^![]()
Me iz jealous!
H20Fidelity
- Feb 11, 2012
It is missing something I wonder what![]()
If I've been spying/tracking all your posts correctly the missing piece is an AK player...
Total: 107 (members: 0, guests: 107)
