The C5 colors the sound and kind of smooths everything out, and the volume pot is a big plus. Another bonus is the portable charging ability. After pairing them up and playing with it for a few days, the F806 and C5 haven't left each other's sides.Bring this over to the new page for you. =)
Yep, figured it might have been while ago. Mine stays naked, I've never amped it either. Funny actually, I was looking for my Sony LOD to try only hours ago after about one year.
- Thread starter RingingEars
Shozy Alien + Vorzuge Duo + Custom art Audio Harmony 8
h1f1add1cted
iBasso DX50 with latest Rockbox + 256 GB SD card > iBasso coax cable > iFi micro iDSD = awesome
RAFA
- Jan 31, 2009
Is there any difference in SQ between coax and usb digital input?
h1f1add1cted
No, because I use that with USB OTG and my Samsung S4 with USB Audio Player Pro and there is no difference between coax and USB input in my case (using only 16bit FLAC files).
Only difference I have is the audio output:
Rockbox = 16/48 with coax
Mango (iBasso FW) = 24/192 with coax
UAPP = up to 384 Khz / DSD256 with USB
raybone0566
Astell & Kern Ak100, Ray Samuels P51 Mustang, Kef M-200, Palics Mini
Montyburns
- Jan 9, 2014
Tell us about those KEF Earphones...
raybone0566
You have to play with them to get a good fit. The nozzles are enormous so tip rolling is limited. Sound is very good, dual driver with great low end. Highs tend to sound artificial. Imaging is very nice with the p51, good detail as well.Tell us about those KEF Earphones...
Montyburns
- Jan 9, 2014
Thanks. Big nozzles for me equals fatter wallet...
raybone0566
You can get the large silicone sennheiser tips on but it takes some time. I probably would not have bought these if I would have known.Thanks. Big nozzles for me equals fatter wallet...
rrg123
- Mar 25, 2014
Back to basics.
NZtechfreak
- Jan 19, 2012
Well, after various other incarnations my portable rig has ended up going back to this (Note 4 replacing the Note 3 seen here):
Currently contemplating getting the Final Audio Pandora Hope VI, which impressed on a brief audition recently. Another upgrade of course will be getting the 200gb microSD when it releases, will save me from having to do case mods to use my 256gb SD card with the phone (as I used to do with the Note 3 at times).
ianeith
- Jan 12, 2015
ianeith
- Jan 12, 2015
