Jan 7, 2009 at 2:45 AM Post #6,781 of 27,319
Originally Posted by ericj /img/forum/go_quote.gif
Hey, here's a stupid idea that nobody will ever test. That doesn't even belong in this thread.
On the contrary, I think it's an excellent experiment. Did Stax make a valid but unwise tradeoff between headstage and diaphragm control when they offed the mineral-wool 'sorber? Only one way to find out, and glue may not be necessary.
PS: I love Smeggy's suggestion to flock the Lambda cage. It's SO Christmas.
Jan 7, 2009 at 3:36 AM Post #6,782 of 27,319
Preliminary results of SFI transplantation to vintage Audio Technica frame: these 125 ohm suckers are really really inefficient. With the Fostex T50RP I have the volume on second to lowest in Windows on this laptop. With the SFIs I have it on max.
Jan 7, 2009 at 5:34 AM Post #6,785 of 27,319
maybe I'm just feeling wary of suggesting strange things, having again made the mistake of disagreeing with someone on AK.
Jan 7, 2009 at 6:01 AM Post #6,786 of 27,319
I really was hoping they'd be more efficient than the 30-ohmers (more but narrower turns, giving higher impedance but also higher efficiency, more Bl product), but no.
Originally Posted by scompton /img/forum/go_quote.gif
This must have been right before they came out with the next generation. They already are using the RP name and the logo that is on the back of the cups.
You're right about the new RP logo, but the RP ("Regular Phase") name was there from the beginning.
Interestingly, the cutaway "photo" of an RP driver is actually the element from an RP microphone.
Oh, what was it this time? EDIT: I see, it's felt. I feel for you. Their application isn't the same as ours, and you have to remember that the tradition of using long-fiber wool in audio is deeply entrenched (transmission-line speakers, need I say more?). Tell them the cheap stuff is just as good and they won't listen. I actually had an AK guy object to my suggestion that dollar-store "magic eraser" pads were cheaper and worked just as well as the branded ones. That's why I don't fool with those folks too much anymore.
Jan 7, 2009 at 6:06 AM Post #6,787 of 27,319
Looks a bit like T10 driver as well.
Jan 7, 2009 at 6:36 AM Post #6,788 of 27,319
Oh, they were discussing the application of felt to tweeter baffles to damp reflections, and i objected to the logic that since one person with some diagnostic instrumentation found that one product was better than another, and the better product was 75% wool and the lesser product synthetic, this obviously means that wool felt sounds better than non-wool felt.
the back and forth is still making me twitch.
"But product A *IS* better than product B! And product A was 75% wool SAE F-13!"
"Product A is better quality / more suitable than product B, but this does not mean that all products made of the same things as product A are always better than things not made of the same things as product A. And the SAE felt standards are 40+ years old, and don't tell us anything other than 'hey we have some felt, and we can tell you that if it bears this mark it has this wool content, and what the tinsile strength and impact deflection are. And F-13 is what we recommend for acoustic damping and fuel oil filtration. - they don't tell us why or how it's good at acoustic damping or filtering fuel oil."
"BURN THE NONBELIEVER!"
"Look all I'm saying is that you don't have to eat ivy to produce fibers useful for this job. 'synthetic' is a big wide field of fibers with all sorts of different properties and lots of them are way better than acrylic craft felt. I particularly recommend rayon. And there's a big wide world of extruded synthetics out there that the SAE people never dreamed of."
"BUT PRODUCT A WAS BETTER! WHY HAVE YOU SUGGESTED NO ALTERNATIVES?!"
etc.
Jan 7, 2009 at 6:45 AM Post #6,789 of 27,319
They say that a burning nonbeliever gives a lovely light. That's subjective, and I have no basis for saying that.
Hey, I gotta get to bed so I'll have enough energy to listen to Smeggy's Worfdales tomorrow! [sfx: zoom]
Jan 7, 2009 at 7:13 AM Post #6,790 of 27,319
Eric, tell those AK guys that the real audio felt Nirvana is in cashmere fabrics. Wool is for cheapies.
Jan 7, 2009 at 7:22 AM Post #6,791 of 27,319
I'm a super cheapie, I use craft felt most of the time.
Wow, these Audio Technica SFIs are super bright, and super fast, with slightly less bass than I would like. Now I know what overdamping is like. All I did was leave the sticker ericj put on as a reflex dot and put a piece of superfelt behind that, with some foam behind that. Once I make the reflex dot smaller, I can easily imagine these to be a cheap self-made SR-X. I bet I can ask you guys for some help increasing the bass though. How would I go about doing this (besides removing the felt behind the driver, in other words something housing or pad related)? Also, I don't have a good way of fastening the driver to the housing, I'm just using some bluetak and the pressure of the foam right now. Any ideas for that?
Edit: Ooh, Wharfedales! Also, I'm first post again...
Edit 2: For future reference (mainly for myself), this is a 124-ohm SFI driver transplantation into an Audio-Technica AT-702 frame.
Mods:
Configuration: Foam -> Disc of superfelt -> Reflex Dot -> SFI driver bluetak'd to frame
Replaced foam in earpads with thicker foam because stock was too thin and my ears were hurting from being pressed into the plastic.
Edit 3: Forget the reflex dot, I'm currently EQing a slope in the treble down to -6dB at 20kHz.
Jan 7, 2009 at 8:02 AM Post #6,792 of 27,319
If you want to be dead sure that the pads seal and isolate well, you can always make yourself a pair of wu-pads of leather. As for now, are you sure that no bass leaks through that foam in the earpads?
Then if you are worried about the seal between driver and housing, you can also try a thin (but springy) foam gasket in addition to the blutak.
Jan 7, 2009 at 9:36 AM Post #6,793 of 27,319
As we are touching the subject of cashmere/wool/synthetic felt, I am almost out of the cashmere blend I and some of you have used to damp the Yamas and other orthos. It's out of production (the company was bought by a mega-corp a while ago) but the store still had (hopefully has) some. The problem is, what they have is barely enough for a coat, and they will only sell it as a whole piece. Is there any interest in a group buy of the last stock left? If we manage to gather 10 interested people, it should amount to 10 euros each with shipping, maybe less.
Jan 7, 2009 at 1:01 PM Post #6,795 of 27,319
Heh heh, yes, that talk is completely wrong as long as you take the time and trouble to completely re-pad it, rewire it, redamp it and reseal it. What were those skeptics thinking? Seriously, it's a great DIY project, and though efficiency is lowest of the orthos, it's not a bad headphone, and it's stupid-cheap to buy; it's just not the one I'd suggest to begin the Grand Ortho Adventure with.
It was just a minor tweak... (?)
Here are the pictures that I promised, that casts better light on the HOK, in the cold snowy north.
