Originally Posted by smeggy /img/forum/go_quote.gif
I'm not overly fussed about the deepest notes, as much as I like them. The Wharfeys sound excellent even though they start rolling off at about 50Hz, much like the K1000 (they are more similar than I like to admit with a little tweaking).
..They have nice bass if a little light, deep but lacking some power there.
..They don't play very loud before distorting in the bass and they need an absolute buttload of power to drive. They are harder to drive than any other orthos, the K340 or the K1000. My floorstanding speakers are easier to drive.
I selected these passages from Smeggy's Wharfencomium to make an important point later on in this post, not to magnify the Wharfey's shortcomings. The advantage of the ribbon is that excursion is not a problem. The disadvantage is that sealing out backwave is a problem. But make the diaphragm big enough and get it close to the ear and bass will be adequate or better, as setmenu has found.
I'm going to see if there's any manufacturing drawings or parts specifications available in their archives. I doubt anyone from that era still works there but hopefully somebody kept records.
They've changed hands a few times, so this may be a vain hope, but I surely hope not. Some old guy living in a cottage in the Cotswolds.. I can see it now.. he goes to look for the papers and finds they've been eaten by a goat. Let's hope these shadows of my imagination are altered by the future. Good luck, Smeggy!
Originally Posted by ludoo /img/forum/go_quote.gif
I dislike of reflex dots on principle... But the principle is the same as the one I and kabeer are using with the donut damping..
Well... no, it isn't. Otherwise felt by itself would be regularly bringing up that top octave, but it doesn't. Felt soaks up treble, though it does reflect some.
I do sympathize with your feelings about the use of dots, which I called cheating when I introduced the idea. It is. If it didn't work so well, I wouldn't use it myself... ..on principle!
Originally Posted by bjarnetv /img/forum/go_quote.gif
seems like wharfedale understood the mysterious technology quite a lot better than yamaha and fostex.
No one exceeds me in my admiration for what the Wharfedalers achieved in the original Isodynamic (aka ID-1), but their design shows that they made some canny tradeoffs (see the selections from Smeggy's post, above), namely efficiency, flux uniformity and low bass, just as Yamaha did. It's just that in the case of the 'Dales, they were pure engineering tradeoffs rather than economic/marketing ones, or, in the case of the PMB 100, design-philosophy ones. What gives the 'Dales the spark of genius is that they did all this using the simplest possible design requiring the absolute minimum of precision manufacture, selling for no more than the typical good dynamic headphone of the time. They damped it well, and even though the enclosure wasn't the best, it's user-removeable!
And yes, if there's any hope that we could make our own ribbon headphones, the Wharfedale blueprint would be the starting point. I just wish there were a lot more ID-1s available.
looking forward to trying them [HP-50] on a proper amp, and i do expect them to transform into an acceptable headphone, but so far they are soundly crushed by the franken-sfi
If you're hearing bass from the 50 but the SFI sounds much better, something's not right. Report back on this one when your amp shows up, okay?
It's puzzling that they [YH-100] manage to be damped without any felt directly behind the driver.
They are being
slightly damped, but I think what's mostly happening is the natural frequency of the diaphragm is being moved up by the near-sealing of the vents. Air is elastic enough that damping by remoting the felt introduces an additional spring that reacts with diaphragm tension/compliance. Go a little easier on the vent felt and you'll be ready to damp the usual way. Or maybe you'll discover a happy medium with no damping but vent felt that's dense enough to bring the frequency response of the headphone in line with your tastes. I look forward to your results.
