chrislangley4253
- Dec 16, 2009
any suggestions on a place to buy that contact cleaner?
Mostly it gives you backwave control, but it also gives you opportunities to tune. There's room for damping material, and of course you can fool with the earpads as well. In my case, since a previous owner had messed up my YHD-2 somehow, the drivers needed a new home.
DeoxiT is available in RadioShack brick and mortar locations now.
Call around. If the thought of walking into a radio-TV electronics supply shop with yellowing blister packs clinging to the walls and old chainsmoking guys (also turning yellow) estivating inside with framed autographed photos of Charlotte Peters on their crumbling desks gives you the jimjams, I understand. Try local electronics repair shops, including the ones attached to stereo shops, if there are any left. The stuff works so well, you're going to want to try it on lots of different things.
Do you guys think 160 is a good deal for a Yamaha CR-1020 in good shape except for the internal lights?
So, back to the monsoons.
I've been doing other things for the last couple days but also thinking about how I'm going to handle this.
I've figured out that i can tension the membrane with nothing more high-tech than blue tape. Whether the tension is going to be correct, eh, who knows. Tension will have to be done before i reassemble.
4/40 1/4" screws and nuts and washers will work to reassemble. Tested that with the 4/40 3/8" screws i use to attach transistors to heatsinks (and may use them for reassembly - I don't believe they are too long. 1/4" would be Just Right).
For the larger holes (where the base attaches) I'll just go over to my friend's house and use normal pop rivets, just like sonigistix did. But failing that, I think 6/32 screws would work fine.
I am currently testing the substance i believe i can use to repair the tear in the membrane i made. Ozark Trail AirStop Vinyl Repair, as found in the sporting goods department at any wallyborg.I have mentioned this stuff before. I've dabbed some on the membrane down by where the cable solders on and will wait 24 hours before testing adhesion and checking to make sure it didn't damage the plastic. I know i could just use a piece of tape, but that tape will fail in a few years unless i get, like, archival grade tape or something. Perhaps someone on the list has suggestions there, I guess.
I'm guessing i can repair the trace with Permatex QuickGrid. I imagine Donald may have suggestions for other substances. But i already have the QuickGrid.
It will come as no surprise to Wualta that i plan to re-adhere the membrane with a thin layer of Permatex Flowable Silicone.
You can easily install a Neutrik RA 3.5mm plug to any cable you want - they have a small footprint.
Oh, my YL is in da house. :-D
Just curious-- what's wrong with the cable Fostex provided?
Nothing, I just want to get a 3.5mm to 3.5mm cable as well.
also, my t20v1 i recabled, and the solder joints keep falling apart, giving me fits. any suggestions?
