MDR30
- Sep 8, 2009
Received a pair of HOK80-2s from Germany with the usual worn/aged pads and a stubborn patina of grime and dust, probably from a smoker's home. That oily, brownish layer doesn't respond to soap or alcohol, but must be worn down by pure patience.
So after putting in a few hours work in a day or two, including changing plug from five pin DIN to 6,5 mm TRS, I sat down and listened. Big disappointment: no bass, piercing mid and treble, plasticky sound (here referring to old transistor radios of same material with small paper cone speakers). I thought this was a lost case but decided to open the headphone since there was an intermittancy contact problem. Followed the guide by ericj (post # 787 in this thread) and added nothing but a circular piece of foam at the back of the driver to press it against the baffle.
Most important mod: took out the plastic disc covering the openings in the back of the cups. Cut the cable and resoldered it to the drivers. No OFC her, the East German copper was green as a dollar bill. Never mind, scraped off the worst and made sure the solder attached.
An now the reason for this post: I tried HD25 pads which fit like a glove, really. Listened again and the difference was huge: nice full sound, warm yet detailed. No wonder Facel Vega (what ever happened to him?) was a fan.
This is about the best PMB-driver type headphone I've heard. Well, at least of the semi-open kind. Work on the DK830 continues.
Gone: DIN plug and disc.
Green copper:
Cleaned HOK80-2s with Sennheiser HD25 pads:
Can be found for less than 20 euro on ebay.de - well worth the investment. Oh, they are quite power hungry and need an amp that can deliver a good amount of current.
Green copper:
