clc77
- Mar 4, 2005
Thanks!!
Not sure what you mean by "mid-low honk", but if by that you mean that there's a lump in the midbass where it meets the midrange, you might need to use denser felt right behind the driver-- ie, you may need to increase the amount of damping. Always get this part right before you take care of anything else, even the top end.
Which brings us to reflex dots, but let's use the euphemism "reflection discs". To answer your question, yes, the effect of a reflection disc is very much dependent on its size.
Reflection discs have become anathema in some quarters, so prepare to be shunned if you use them. Their use was originally intended to prop up only the top two octaves (5k to 20k). The theory goes like this: A disc of a certain diameter will let sound wavelengths greater than that diameter diffract, or bend, around the disc. Wavelengths shorter than the diameter of the disc will reflect back, adding to the original sound, since the reflection point is virtually on the diaphragm itself. In real life there's no sharp cutoff-- as frequency rises from the bass, a reflector disc will reflect nothing, then a little, then there will be a more sudden increase around the point where the sound wavelength matches the diameter of the disc, then back to a gradual rise to a shelf or plateau after that. In speakers there's an analogous (but reverse) phenomenon called the "baffle step".
Or in ballet, the pas de baffle. But that's not important now.
By combining porous tape (MicroPore, TransPore) with felt, you might be able to make a reflector large enough to reach down to the point where the dreaded Ortho Droop begins (according to Yamaha's response graphs, this could be as low as 1kHz !) without sealing the driver and creating a tweeter. And to do this right, you'll want to experiment with several disc sizes. Try a whole bunch of little ones. Or one big one (maybe 19mm or so) smack in the middle. Then add a circle of little ones orbiting around the big one. Since the ear is not omnidirectional at all frequencies, some experimentation (and research) is in order, because it may be possible to cheat. I love it when that happens.
Of course, since the traditional treble control hinges at about 1kHz, you might just want to take the easy way out and do the correction electronically. It's only about a 3dB/octave slope, so nothing radical is needed.
Was that the switch to the new forum software?
Just type your search phrase and add site:http://www.head-fi.org/forum/thread/111193/orthodynamic-roundup
Thanks Wualta, I will play with it following your suggestions. Any way I'm a bit at loss about the wavelength/dot diameter match. At 10Khz the wavelength is supposed to be around 3.5cm which makes for 70% of the surface of the driver with a single disk.
Also, as the hp1 driver has a perforated magnet enclosure, isn't the magnet holes diameter the only reflection area you can really work with? In this case the reflected frequency is far above audible. Am I doing a mistake and should instead apply the disks on top of the felt and not directly on the driver? What's the effect of the distance of the disks form the diaphragm (in terms of phase for example)?
I wasn't completely serious about this, and I do know that at least the old Lambda Pros can sound pretty terrific. But I still find 9 of 10 Staxes simply boring (the same is to be applied to the HD800 BTW).
I'm on a constant search for best-as-possible musicality, other stuff like audiophile merits are partly subordinate for me personally.![]()
well of course you guys couldn't find any. BMF bought 'em all XD
I wonder if that's one of the reason that fostex went for serpentine design on its drivers meant to have an open shell.
Here's a picture of my crew setting up my new speakers. Once they get it into my house, which you can see in the distance, they're going to drill holes in it and slap a diaphragm in there. I'll let you know my impressions.
The treble droop , I suppose, is an inevitable consequence of non-tensioned diaphragms.
I guess these diaphragms would need more damping compared to a tensioned diaphragm to produce similar treble response.
Just the reflex won't do.
