apatN
- Mar 28, 2007
Are they really worth 250€?
Let me put it this way: All my other stuff has become awfully midfi-ish and thin meanwhile...
Bought another NAD RP18 for the team: Ebay Germany
We'll see if they are for NoXter or for Rhythmdevils finally...
The Alessandro included?
... The idea came from my rapid product development class, where my lecturer showed us some prototype sample made by a RPD machine glueing paper layers together. The quality of it ( by touching, knocking...) is almost like wood. How does the idea sound to you guys?
BTW... the first can I bought with my money in my 20s was a YH100. I left it behind in Italy when I moved to UK and, after have read almost half of this long thread, I'm pestering my sisters on its quest. I really hope one more yh100 could be brought back to life.
Nice! Glad to see a few more RP18s are coming into circulation. As I spend more time tweaking the damping, the better they get.
Yes, the more NADs in the hands of experimenters, the closer we'll be to getting at its potential. Let us know if you find the One Easy Thing that basically untilts the response curve.
Originally Posted by DefectiveAudioComponent /img/forum/go_quote.gif
Buying that version might be the Easiest Thing.
Unless it's the version without tilt, that doesnt really require any modification..... Buying that version might be the Easiest Thing.
Originally Posted by BoilermakerFan
He did say "... ALL my other stuff."apatN said:
I somewhat disagree. As I've understood it, the so-said "good" bass light version is to be kept stock principally in order to sound best. I personally wouldn't fancy to have that monster with its stock supraaural pads, the T20v2 is painful enough. My bass-heavy RP18 with W11 or taped DT770 pads is comfort heaven, and it also provides SS worth mentioning.
I have the suspicion that the NAD is LCD2 quality for HD600 money.
