[COLOR=222222][COLOR=898F9C]
Secrets of Home Theater and High Fidelity recently posted this:[/COLOR][/COLOR]
[COLOR=141823]Here are some spectra from bench testing the new OPPO HA-1 headphone amplifier. The spectra look very, very clean at the signal peaks, in fact, some of the best I have ever seen from what is essentially a low wattage speaker amplifier. Second and third ordered harmonics predominate, and this gives a terrific sound. For the IMD test, there was no measurable second harmonic at 14 kHz (from the 7 kHz fundamental test tone), so the IMD is incredibly low, and this results in the sound having marvelous detail. The numbers are a bit high, due to some inaudible (but measurable) noise in the 0 to 2 kHz region, and with the signal peak at about 1 volt, the noise is a larger proportion of the calculated THD+N than it is with power amplifiers tested at, say, 10 or 20 volts.[/COLOR]
[COLOR=141823]The HA-1 is definitely one of the finest headphone amplifiers ever made. I performed these tests on an Audio Precision, which generated the digital signals. The coax digital input on the HA-1 was used. These initial graphs are for 16/44.1 samples. The full review is scheduled for publication in Secrets shortly.[/COLOR]
[COLOR=141823]
[/COLOR]
[COLOR=141823]
[/COLOR]
[COLOR=141823]
[/COLOR]
[COLOR=141823]
[/COLOR]
[COLOR=222222]
[/COLOR]
[COLOR=222222]
[/COLOR]
[COLOR=222222][COLOR=333333]Some more details about the OPPO HA-1 headphone amplifier. It will decode PCM up to 24/384 and DSD up to DSD128. These are both emerging high resolution codecs, and music is available from 2L in Norway. I believe some of the high rez music websites may be starting to offer downloads in these formats soon. Right now, I listen to the HA-1 using my iPod connected via USB on the HA-1. So, that sends t[/COLOR]
he digital bitstream directly to the HA-1's DAC rather than using the RCA analog inputs, which would use the iPod's DAC.
The extremely low measured IM on the HA-1 means you get very fine details in the music, and since the headphones place the "speakers" within an inch or so of your ear, you can hear all those details that get lost when you have speakers across the room. Take a look at some other power amplifier reviews we have done at Secrets, and you will see how remarkable the IM results (as well as the 19 kHz, 20 kHz test results) are on the HA-1 in comparison.
The distortion spectra were taken with the HA-1 set to 0 dB, which is a bit louder than I would listen, but you may need it with lower sensitivity headphones. The HA-1 volume control will go higher than 0 dB, but for these initial tests, I decided to use 0 dB, since that is a standard way of measuring a "typical" volume setting.
More later . . . .
[/COLOR]
