Noble Audio - the Wizard returns!
Nov 30, 2013 at 10:20 PM Post #482 of 36,078
  http://nobleaudio.com/support/impressions-instructions/
   At the least, open mouth, a lot of audiologist, hearing aid dealers do not have bite blocks.
Noble Audio Stay updated on Noble Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/NobleAudio https://www.twitter.com/noblebywizard https://www.instagram.com/nobleaudio https://nobleaudio.com/en/ contact@nobleaudio.com
Nov 30, 2013 at 10:23 PM Post #483 of 36,078
  Thanks John. It's the 50/50 two wood that really makes that design work for me. I honestly didn't notice the gold nuggets until you pointed them out.
I've ordered a Wizard design Kaiser 10 and have inserted a link to that image in the notes field. Do you suggest using a bite block when getting your impressions done?
As I stated, getting a 50/50 wood face plate would be difficult, and the design in the photo was a miracle to do in the first pace as wood is very random.   Two Tone Amboyna, we can supply for sure....   but a 50/50 ratio we could not insure that. We can look into it and see if we could find a way to do it, but no gaurantees.
Thanks
Nov 30, 2013 at 10:24 PM Post #484 of 36,078
I'm not The Wizard, but I would recommend using a bite block when getting impressions. It helps a lot for some people so you won't lose the seal when you smile or yawn or swollow or sing, etc.
And since having a seal makes all the difference in getting the best sound, try to work with an audiologist who has experience with musicians' monitors.
Nov 30, 2013 at 10:44 PM Post #485 of 36,078
Sure, that is ideal, but Noble customers are world wide, and in some areas of the world, a bite block is unheard of.
Consider this, the number of University Audiology programs in Singapore is 0 (as in ZERO, as in NONE)
Nov 30, 2013 at 10:49 PM Post #486 of 36,078
Well in my (humble) experience, using two fingers will replace the bite block.
Nov 30, 2013 at 10:54 PM Post #487 of 36,078
Whoa.
Nov 30, 2013 at 11:12 PM Post #489 of 36,078
Thanks
No problem John. I'd be happy to own any of your custom wood designs.
Nov 30, 2013 at 11:22 PM Post #490 of 36,078
I've found that dental supply stores will have bite blocks for sale.  If I can buy them in a third world country (Colombia) I think it shouldn't be overly difficult to obtain them elsewhere.  I do think a good audiologist will supply them, but my first audiologist used a thick popsicle stick instead.  The second audiologist had bite blocks and his results were far superior (for more reasons than just the bite block).  This might be one of those 'test the waters' questions you can use when you're searching for your audiologist.
If you're near the Vancouver B.C. area (Lower Mainland) I give my strongest recommendation to:
Jamie Larsen
#108 - 7885 6th Street
Burnaby, BC  V3N 3N4
support@simplehearing.ca
www.simplehearing.ca
604/528/8884
Fax: 1-877/652/3934
The man has his own CIEMS and is both intelligent and patient.  He won't let you walk out if your impressions aren't excellent.  This guy knows what he's doing and as a result two refits (Custom Art Pro330 and JH13Pro) now fit me perfectly.
Nov 30, 2013 at 11:29 PM Post #492 of 36,078
Jamie Larsen
Burnaby, BC  V3N 3N4
604/528/8884
Fax: 1-877/652/3934
   Great info
Dec 1, 2013 at 12:14 AM Post #495 of 36,078
The difference, I believe, will vary from listener to listener. I own the 4.A (CIEM) and had the oc or notcasion to listen to the 4.Ai (IEM): same drivers, same configuration, but to my ears not at all the same sound (with the 4.A a clear winner). A couple other people got to compare the two and also found differences, though not as much as I did. My ear canals, however, are 2.5 times larger than average, so I'm not a representative sample -- but are you? Another advantage of CIEMs, beside the perfect fit, is also, I surmise, a more consistent sound. However, you may note that the Wizard himself enjoys one of his universal IEMs (the Noble 6) best of all.
Thanks, that was actually a great answer to my question a few days back regarding the difference between the NB4 universal and NB4.  So I thought that it would benefit others to bring it up right before the 20% deadline
 or not...
  Sorry to hear about your 2.5 times larger ear canals than average. I'm sure it benefits you in other ways.. I mean larger ears, feet etc often indicates a larger sized libido or something else more measurable that out female counterparts may enjoy.. Okay, I'm very well aware of that I'm out of bounce..
