Lépine
Actually I do agree about the computer. I don't think most people are aware that the computer can and often does sound different. I believe there are many reasons the computer can have a noticeable (not big) difference. In my experience, using applications like HQPlayer the GPU and overall computational power of the computer makes a difference in how smooth the filter sounds. I use two 32Gb 3070 ti i7 20 core
laptops. One queues the music from the library and streams it to the other as a WAV. The other upscales it. All the computation is off boarded using CUDA api to the NVidia processors.
In comparison, I have a Microsoft Surface Pro 7, the was top of the line with the best i7 32 Gb. It sounds dull in comparison because the USB transfer speed slows down. I assume the M-Scaler is somehow trying to retime the difference. I can tell this because it takes much longer to buffer the song before it plays. Also obviously I have to use much simpler HQPlayer filters.
I know I read a lot about the GPU adds noise into the USB signal path. I can't tell if it is there or not. I can though tell that the more
powerful computers sound more open and organic. Now I know that if I am dropping packets, I should hear stuttering or other digital artifacts that's not happening and the so called smoothness is likely in my imagination. I don't have a wire shark or something similar to sniff the ip addresses and see if i am dropping packets or not.
I don't really consider digital connections as interconnects, and I would be surprised if these connectors can be improved with Kimber Kable level connectors. Analog connectors on the other hand, I have a drawer full of them of different alloys, weaving patterns and brands. I also have a laboratory grade power filter that is used for the ups for controlling the laser used in brain surgery. I live in a condo so you can imagine what the electricity is like with 6 different house holds tapping the main.
I am not a DAP person apparently. I haven't found one that I truly like in terms of "house sound". All of them have a some designed or
unintentional sound that are not to my taste. Yes I agree these are purpose built devices, but still they are often weaker in output,
color the music, slow and difficult to navigate, and they can not upscale. The only advantage that is clearly superior is the noise level which to me is nonexistent in most cases.
Also, have you noticed that just about all of these DAPs don't sound good as USB tethered players? They're all bad especially the Sony. A Chord Hugo2 is hard to beat as a portable dongle
I'll leave all the rest in a draw when I am at home.
Ah, and you are probably right, Chord is probably another "house sound" a much dryer or reference like one perhaps.
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
