For a connector? How? :O
There were systems there with speaker cables that cost $60,000 usd that is down right crazy. I guess if you have the money to blow it doesn't matter. It is a status symbol.
I seriously want to know what kind of customers whoever selling those cables have...mind blowing.
I am referring to the way Noble handles the sockets in general. One of the thinner cables did get loose in my Khan, but the Khan cable itself always fit well. If you remember I had to use the thinner cables due to the noise issue.When you wanted me to put your aftermarket cable on and I said I didn't feel comfortable doing it, which set was it, the Khan or Encore? I know I sent you to the Effect Audio booth to do it.
Here are some quick impressions of the solaris as compared to the Khan.
... If there is anyone else out there with both the Khan and Solaris I am keen to hear your impressions as well.
Like you I also like both and enjoy jumping from one to the other depending on music and mood. Right now, I can't live without either actually.
I agree with most of what you say, especially about the tremble, and the bass is pretty accurate as well, from what I hear.
At first I thought they were pretty close in sound but the more I listen to both the more I hear differences.
Also, the Solaris has more hiss on my non-Sony players, on the Sony's they sound fine. Actually Sony players make both the Khan and Solaris sing like no other earphones.
Khans have a better fit to my ears as the Solaris are bigger.
Actually, now that I think of it, I did try my EE cable on my Savants for about 3 seconds and hated it but it fit fine.. so either the Fearless cable is weird or my Katanas are unusual..
I found this adapter on ebay for $33 so I'll probably just go that route with a 2.5mm Noble cable.
Yep, AFAIK, they have been using the 0.78mm connectors since the K10 days.The 2-pin connectors that Noble uses should be 0.78mm. The 0.75mm 2-pin connectors are the extruded ones that QDC currently use, and Ultimate Ears and Unique Melody used to use.
I have a Solaris, and I'm about to purchase a Khan myself. I'm driving both from a Hugo 2, and my impressions mirror yours pretty closely.Here are some quick impressions of the solaris as compared to the Khan.
Bass
Kahn has clear and well defined sub bass that slowly rolls off into the mid bass and lower mids. The solaris has more pronounced mid bass and than on the Khan. There are times when I feel that the Khan has more impact in the bass than the solaris. This might be due to the way that the mids are presented with each iem.
Mids
The two both present the mids differently both are enjoyable. The solaris has a more forward mid range where with the khan they are slightly pulled back. the presentation with the khan seems more airy. With classical music there is more depth to the soundstage. and better layering of the instruments. the brass presents to me more life like. I can see some people prefering the solaris with more modern music over the khan.
Highs
The highs on the khan are much clearer and faster on the khan. This might be due to the piezo tweeter. The highs on the Khan are the closest to the kse1500 that i have heard. There is more air with the khan and more "sparkle" as well. the sound stage with the Khan presents deeper and the imaging is a bit more precise with the Khan.
I like both and need to spend more time with Khan to make a final decision on which one I prefer. The Khan only has about 20 hours on it and the solaris is well over 200 hours.
As a side note the Khan is more comfortable than the solaris though i do not find the solaris to be uncomfortable. I prefer both of them over my roxanne 90% of the time I find the roxanne to warm now that I am used to the lcd4z as my daily driver.
More to come on this later. If there is anyone else out there with both the Khan and Solaris I am keen to hear your impressions as well.
I can say the aftermarket Han Sound ZEN 4 wire cable I purchased dropped the lows from the Encore even though it was 4.4mm. So for me the aftermarket cable was not an improvement?I had a friend back in my 2 channel days who used to put cotton balls at strategic spots in his listening room. I've done my fair share of tweaking that others might consider insane so, yeah, I hear you.
The connectors on that pigtail look to be of decent quality so hopefully any change isn't detrimental if I go that route. I may still just gamble on an aftermarket cable and hope for the best.
