Noble Audio - the Wizard returns!
Oct 9, 2017 at 4:00 PM Post #26,326 of 36,062
Oct 9, 2017 at 5:06 PM Post #26,328 of 36,062
They haven't opened it up again yet. Check back in about 1 hour. @CEE TEE made the announcement that they would be making the additional units available in about 3 hours. That was 2 hours ago.
Oct 10, 2017 at 4:44 PM Post #26,331 of 36,062
Jumped on the drop, as it is time to retire my old UE Triple-Fi 10vi's. I listen mostly to Jazz, Pop and Hip-Hop and enjoy a respectable amount of bass. Hopefully I made a good decision.
Oct 10, 2017 at 9:31 PM Post #26,332 of 36,062
@FullCircle
Dear Mr. Wizard,
490 unit in all, gone in less than 48 hours combined, with just 2 months to work on it, now do you still do hand assembly and test in the US ?
I'm actually split between worrying about your staff facing this amount of work, and the quality control of this massive order... These high end iems are intricate...
Oct 11, 2017 at 1:15 AM Post #26,333 of 36,062
I ordered the massdrop K10s.
Just had 2 questions, hoping some more experienced headfi-er could help me with:
- does the anodised color on the aluminum scratch off easily?
- what would you recommend as a lightweight and small case that can still protect the K10s? Can't really carry the pelican case around as I don't usually carry a bag around
Ps. I was trying the Encores at a audio shop and the boss dude told me that something new was going to be released in the coming weeks!
Oct 11, 2017 at 1:46 AM Post #26,334 of 36,062
Seems like the MD one's does not follow the new norm for Noble, in which all the universals come with the round case now. So you can try aiming for one of those.
In terms of the anodised colour, not seen many (if any) complaints about this as long as the proper care is given.
Oct 12, 2017 at 10:14 AM Post #26,335 of 36,062
If you're using the stock cable, the IEMs and the Noble cable should fit rather snugly in its supplied pouch. Or get a similar pouch - they cost a few $ at most. However, if you're using a 3rd party cable, with a larger wire size, you'll definitely need a larger case. Perhaps, something like this? It's a little expensive, but you can try hunting for something similar. Not as bulky as a Pelican, but big enough to store your K10 and an aftermarket cable.
Oct 12, 2017 at 4:39 PM Post #26,336 of 36,062
Buy the round Noble case, I used it with my customs and a thicker cable, it fit perfectly. Now that I am using the stock cable, there is even more room, even have a silica pack in it. Okay, been here too long already, peace out.
Oct 12, 2017 at 5:05 PM Post #26,337 of 36,062
I really liked the Campfire Audio cases, specifically the Canvas Case with the fake lambswool interior. It's a small, pocket-able, sturdy case -- only around $29.
https://campfireaudio.com/shop/canvas-case/
Oct 12, 2017 at 9:24 PM Post #26,338 of 36,062
Today at work I listened to a lot of Encore, using the Effect Audio Thor Silver II cable. Which doesn't give me the best seal most of the time. But with the MandarinE Symbio W tips, they stay in like a champ, even with that cable.
And oh lord, the sound is sublime!
Oct 12, 2017 at 9:41 PM Post #26,340 of 36,062
I am now rocking the AK240 Blue Note, thanks to dropping my other AK240 on Saturday and shattering the glass. I paid for the price of the new glass and Owen just gave me a Blue Note unit and I was out the door. I should have broken my other one a long time ago. :wink:
