All right, I've managed to solve my two gripes with the Aiva, the headband slider and the searing treble.
For the sliders, I turned them inside out. The leather headband passes through the metal headband, now the weight instead of being held on by the friction on the plastic sliders, the force is now directed a more towards the center and not as tangential as before, they are now held in place and don't slide down.
For the highs, I played around with the foam inserts of my DT-770 and a pair of Brainwavz of sheepskin earpads I have. The earpads dampen the highs a bit, bring the mids a bit more forward and give the bass a slight, but not massive boost. When I added the foam inserts of my DT-770 they dampened the treble, but not enough. When using the two foam inserts sandwiched on one side, the treble is significantly better. I went ahead and got a sheet of 5.5mm thick foam on a local shop, cut 4 foam inserts and placed two per each side along with the Brainwavz earpads.
So much better, the treble is still detailed but now it's properly dampened; to my ears at least.
