NEW - Campfire Comet and Atlas
191 192 193 194 195 196 197 198 199 200
202 203 204 205
  1. davidcotton
    If I were spending that much for that atlas I think I'd go a bit further and get the equinox my self.
  2. Starcruncher
    There have been numerous comments about Atlas being heavy and prone to falling out of ears. Both points have merit. Weirdly, though, when using other iems, which are all much lighter weight, I feel something's lacking - it's kind of like...being naked. The heft of Atlas, for me, is an odd, unforeseen benefit.
    I use Spiral Dots with the cable down, for what it's worth.
  3. KevP
    Yes, I also use Spiral Dots with the Atlas. Tame the bass just a bit more than the Final Es and open up the treble. Still the driver flex though. Foam tips eradicate this, but make the bass a bit too overpowering for my taste.
  4. Luisonic
    I use Atlas with Spirals, cable down and a simple shirt clip (kills the weight and secures them) and they are the most comfortable, musical and engaging iems you could wish for.
    I think that the bass and sub-bass issue is very player dependent. I use them with the spkm, and it is a fantastic combination, presenting the lows into a coherent whole with the music. I'm not a bass head at all (always preferred analytical listening) but now, I'm not so sure if I'd be willing to renounce this bass for whatever else!
  5. zephyrstar
    Same for me, they go way in my ears and are very comfy. The clip helps absorb the weight. Love them with metal!
  6. davidcotton
    Interesting, I was always under the impression that the bass of the atlas tended to swamp the vocals etc of metal. What type do you listen to?
  7. Tristy
    not at all, they are very balanced tbh emphasised on both ends but at the same time the mids are still there. I love them with metal, lately I’ve been listening to a lot of Slipknot, of mice and men, korn and the new Northlane album and they are great.
  8. zephyrstar
    Older metal (roots metal? ha, sounds weird to say that) where the recordings were sort of thin. For instance, on some of the earlier Megadeth and Metallica albums the bass was pretty weak in the mix so it can use all the help it can get. Rust in Peace sounds great with these!
    davidcotton likes this.
  9. cooperpwc
    I am a newer member of the Atlas cult, about three weeks in. These are remarkable IEMs. Their coherence and transparency is mind-smacking. This is a huge dynamic headphone inside my ears.
    I am blessed to have minimal problems with driver flex. The sound sometimes goes soft as I insert and then the IEMs settle and everything equalizes. For me, it is a non-issue.
    I have found that a shallow fit with larger Final E tips (size up) produces the best sound quality.
    Congratulations Ken. The Atlas is is real achievement.
    nephilim32, Tristy and arftech like this.
  10. arftech
    Received my Atlas this past Saturday and I’m trying to train my brain to get used to the signature. To me the Andromeda seems to be more coherent even though it lacks the low end of the Atlas. What tips do y’all recommend to smooth it out.
    nephilim32 likes this.
  11. tlcocks
    I had both before I returned the Andros. For me, only the jvc spiral dots offered up as competent and cohesive a midrange as the Andros while not sacrificing the bass. In short, JVC SD’s sounded better than any of the supplied tips with the Atlas.
    arftech likes this.
  12. arftech
    Which fitted JVC spiral dot did you use?
  13. Lookout57
    The Atlas needs 150-200 hours of burn-in to reach it's potential.
  14. cooperpwc
    Everyone keeps talking about Spiral Dot tips. The Final Audio E Types fit me well on the Atlas (XL sitting shallow in my huge ears). But I have to see what all the fuss is about. :-) Ordered.
  15. Luisonic
    Don't know if it's been said already or read, but remember: massive burn-in required to get the true sound qualities! Burn at least 200-300 hours, and then you'll see. Spiral dots a must.
    arftech likes this.
202 203 204 205
