Meier Audio Quickstep (also Stepdance and 2Stepdance) Discussion and Impressions Thread
Sep 3, 2010 at 4:43 PM Post #91 of 3,070
I ordered my StepDance a few days ago and its on it's way. Can anyone recommend a quality, regulated 15V U.S. power supply?
Sep 3, 2010 at 7:26 PM Post #92 of 3,070
Here is a 12V regulated power supply, but not sure how the common person will get the correct plug on it.  I replaced the plug on my regulated 12V power supply.  I have not seen a 15V regulated power supply; if anyone knows where you can buy one, please let us know.
Yes, the Stepdance does well with the LCD-2, but high current/high gain mode drains my 200 mAh battery quite fast (less than 4 hours?).  My battery charger and batteries will arrive mid next week...I will see which is the best of the 3 different types I am getting when I have time.
Sep 3, 2010 at 10:24 PM Post #93 of 3,070
12 volt regulated would work very well. That's going to be doubled on the rails to produce 24  volts of power. As i understand, it's actually safer to stay a little bit shy of 15 volts although "regulated" is meant to ensure that you never exceed that absolute maximum.
Sep 3, 2010 at 11:54 PM Post #95 of 3,070
How about this: http://www.mpja.com/prodinfo.asp?number=9600+PS
And a note on the sound...the Stepdance is exceptional with just about anything I have thrown at it and sounds awesome with my iPod.  Fantastic detail, dynamics, and bass impact/control.
Sep 4, 2010 at 12:20 AM Post #97 of 3,070
Check this one out http://www.amazon.com/Mastech-Regulated-Variable-Power-Supply/dp/B000E129EU
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=360293935584&rvr_id=134341766970&crlp=1_263602_263622&UA=WXF%3F&GUID=d9fed95b12a0a06c1d9108a1ffe4e672&itemid=360293935584&ff4=263602_263622
Its cheaper than some fancy cables. A better amp power supply will make your amp sound better than an expensive cable.
Sep 4, 2010 at 1:54 AM Post #100 of 3,070
@cooperpwc: Is that the latest Classic (7th gen)?  Should be a nice match.
@wuwhere: why are you looking at 30V power supplies?  The one I linked to is 18V, much lower priced, and I think fine for the Stepdance.
Sep 4, 2010 at 3:18 AM Post #102 of 3,070
Joe, I made sure that the box said manufactured in 2010. So I think that it should be the most current.
Hey cooperpwc,
let us know how the line out of the classic compares to your iphone..
I'm sort of in the same situation, debating whether to get the classic or new touch...
160gb would be great as I have already filled up my 6th gen 80gb classic. but from what I have read here people are either strongly for or against the classic sound..
Sep 4, 2010 at 3:43 AM Post #103 of 3,070
My portable sources (line out) subjectively rank by sound quality based on my experience goes like this:
1) iMod w V-CAP dock
1a) DIY iPod w/film caps
2) S:flo2 (supposed to be better with the 2.3 firmware)
2a) iMod with standard dock
2b) Fuze via LOD with film cap dock
3) iPhone/iPod Classic/Touch
3a) Fuze via LOD with Aluminum electrolytic caps
4) Fuze/Clip HPO to amp
To me the difference is in the detail and space of the sound, which can be heard with better equipment, at least for me.
If you want a large player and don't want to either spend a fortune (iMod) or DIY (my 240GB setup), your choices are the iPod Classic, an old Zune, or the 128GB Touch.  Of course, you can get something else like an Archos but per these forums the Archos lacks SQ.  Anything I missed or any other thoughts?
Sep 4, 2010 at 3:44 AM Post #104 of 3,070
Problems gone after inserting 9v battery . :)
Any IE8 users pairing this with Stepdance ? Do you guys use low / high gain for it ? Currently i'm using low gain . :)
It's like 1 sec the mids are " in your face " type then another sec it goes back to original imaging . I just bought my Maha 9v battery . Currently it's charging , will try it out tml and hopefully the problem doesn't persist .
Sep 4, 2010 at 3:51 AM Post #105 of 3,070
with all my apple lossless files, I most likely will stick with an apple DAP. Also, using mac computers, I don't really have any complaints with itunes like some others here on the site.
how I wish apple came out with a 128gb touch....
