ianmedium
- Jul 6, 2008
I am so glad your enjoying it, as the hours pass the sound gets even better! I am also happy there is another 5000 user who thinks the same way I do on the synergy of both!
[snip]
...if anyone concludes that they really like the difference in sound quality offered by the Stepdance when operating at higher voltages, this is about the best (lightweight, affordable, and safe) portable solution I've found to date for operating near the 15-volt limit: The Blue LiPo 4-Cell 1000mAh 4S1P 14.8v 20C LiPoly Battery and a proper charger to go with it. These 14.8-Volt 1000-mAh LiPo batteries cost only $9.70 each (less than half the price of the 8.4-Volt iPowerUs internal batteries I'm currently using) and they're small enough (at 74x35x23mm) to fit into a small camera case along with the Stepdance and your DAP of choice. They will have none of the regulation and potential AC line noise problems associated with the PSU's discussed above, and they contain a chip that prevents them from being charged to voltages higher than 14.8 Volts - perfect for pushing the Stepdance to its limits. And if you're willing to carry larger, heavier, 14.8V LipP packs that work with the same charger, consider this 1800 mAh pack, or this 5000 mAh pack.
As with the Tripp-Lite PSU, if I eventually splurge for a 14.8-volt LiPo rig, I'll share my findings.
Mike
[snip]
I just came across the skynet WND-1505-R.
This is potentially a 15V linear regulated adapter.
[snip]
Hi everyone, I am pretty interested in more info about the experiences with those 14.8v battery packs. Especially the bigger ones should be pretty interesting. Can you just put them in the amp or do you need to connect them externally? Greetings, Anouk,
Mike
I'll take pictures as I go, in case anyone wants to PM me for step-by-step photos. I could also post them to this thread if there's enough interest.
I'm just jazzed at the thought of running the Stepdance portable at 14.8-Volts. More voltage = more headroom = more slam!
Mike
[snip]
Mike, my god but that is a pretty rig!
One thought: For portable use, you might get some shorter cables for the LCD-2 that are also terminated in a mini plug. That adaptor is a lot of stress to put on the Stepdance headphone jack over time.
[snip]
I notice a difference between 8.4 and 9.6 volt powerex batteries!
I would love to see how you connect the 14.8 to the stepdance for portable use, pictures speak louder than words to folks like me who are completely non technical!
Once again, excellent set up and I would love to hear your thoughts on the stepdance/LCD synergy.
[snip]
[snip]
Zilch, that setup looks gorgeous! I too vote for a full a pictorial as possible, especially as I am terminally incapable of this kind of electrical work (I've never even held a solder gun, let alone used one)
Hi ianmedium!
Thanks for head-swelling compliments!
Seriously, all I've done is spend money. There's been a little bit of original thought, perhaps, in deciding to go with the Sony PCM-M10, but otherwise, I was just doing a lot of research (reading many threads) here on Head-Fi to design this rig. So, I appreciate all of you for your admittedly superior knowlege and many contributions to this forum. In my eperience, there are very few online forums, on ANY topic, that can compete with Head-Fi for sheer collaborative spirit.
While I'm expressing my appreciation, he doesn't know this yet, but basically, for the amp and the cans, I just bought what Skylab recommended - in his reviews of the Stepdance and the LCD-2. The truth is I don't have any other gear (besides a Sansa Clip, Shure SE530's and a pair of Sennheiser HD280 pros.) I just took a big bungee jump on the respect that everyone here at Head-Fi has for Skylab's opinions. So... It's almost entirely his fault!
I also put some failth in impressions offered by average_joe, who preceded me (among others?) in discovering that the Stepdance can drive the LCD-2 quite nicely.
Mike
