Have been burning in my stepdance for around 150-200hrs using an external power adapter since buying my stepdance a month ago.
Using it with my Hifiman HM-801, connected with TWag IC with Oyaide Plugs.
Tried blind test with:
- HM801 headphone out directly with my JH13pro
- HM801 line-out with Stepdance and with JH13pro
Can't tell the difference at all. i.e. I can't guess which one is with the stepdance and which one is directly from 801 headphone out.
Something must be wrong with my hearing?
John
There are three assumptions IMO:
1) HM801's PO is as good as Stepdance (no performance difference)
2) JH13Pro is so efficient that both HM801 PO and Stepdance are more than enough to allow it to perform at its best (amps have performance difference, but the IEM can't reveal it)
3) You can't tell the subtle difference (amps have performance difference, IEM is able to reveal it, but you can't tell the difference)
Personally, my opinion is inclined to (2). Not that many IEM are good at picking up subtle difference on the source IMO.
