Is there a way to fix this?
Try this: take the battery out, turn the pot to max, then all the way down to minimum (without switch off). Repeat for 1 minute or so, then put the battery back in and listen.
you mean take battery out without switching it off and repeat without putting the battery back in?
Taking the battery out is just a precaution. If you are not connecting it to a headphone and source, it really doesn't matter..
Can you describe the cracking sound in detail?
Is it like light tick-tick-tick sound? If it is, that actually the sound of the digital volume control switching between resistance and perfectly normal.
Maybe change your battery? It could be that.
Is it ok to use iem with low sensitivity below 35ohms or will it cause damage to the iems or amp itself?
You can use headphone of any impedance. What control the power is the volume knob.
I'm mean can it be used on high gain without causing long term damage to low impedance iems.
As a new proud owner of HD800S, I am excited!
Meir Audio Soul is what Lieven from Headfonia considers best amp for HD800s
Source: http://www.headfonia.com/report-canjam-europe-essen-2016-part-2/3/
