genclaymore
I have used 2x LME49710NA, 1x LME49720HA and 1xLME 49860 in the amp without any issues but I not using 0 gain.
Question about op amps...
Someone, I assume you Chis said somewhere that 4562 may not be stable on 0 gain setting..... (cant seem to find where now)
What specs do I need to look at to understand why?
I have a dual 49990 and a 49860 i am wanting to try and wondering if they can be used on 0 gain or not?
Cheers
Thinking about getting an OPA Moon for my M-stage, but does it even fit in an M-stage? Also, if I'm buying one I'll order it from ampcity.co.uk and they have an "Optional extra" which is "Extension cables for dual OPA (100mm)", what exactly is this for and do I need it?
Yes, you need the extension cable. OPA Moon/Sun/Earth are far too big to sit upright inside the M-Stage.
BTW, If you have the M-Stage with the built in USB DAC I don't think there is enough room inside for the AudioGD opamps.
My TF.10's don't hum or anything, nor any of my iem's i tried a half dozen, none of them had any artifacts in the sound. If your triples have the mic in them, that's probably the problem...
Those of you with the LM4562, have you added the resistors to class-A bias your opamp, or is this not necessary for the LM4562?
My TF10 are equipped with the UE Custom-Cable and still hum quite noticeably at the lowest gain setting. I already tried a different power cord, a different plug (wall plug) and tightened up the screw at the bottom of the amp.
By the way, I noticed something interesting: if I set the volume knob around 3/4 or more volume the hum increases a fair amount just by touching the metal knob of the potentiometer. At lower volume settings nothing audible changes. What could it be (maybe the alps itself)?![]()
Edit: I took the dac module out and noticed it wasn't the reason for all this hum with my IEMs. The noise created by touching the volume knob increases with the volume setting itself. It sounds different than the hum which is always there.
Sounds like an internal problem with the amp...
Originally Posted by the search never ends /img/forum/go_quote.gif
And I don't feel the usb version is worth buying.
TF10's aren't especially prone to problems with amps, in fact I think they improve more than most iem's amped.
I saw where one member had a tough time getting responses from him, that is not my experience though.
