ninjikiran
- Jul 1, 2009
Using 0 gain with the biased opamp with my LCD-2's. These thigns are more detailed than the k702's, without any annoying sibilant note fatigue.
The Pre-amp out (not line-out, that's what DACs and soundcards tend to have) is always active.
Not sure on that, unfortunately.
Quick questions:
I have the Logitech Z2300s (I know they aren't very good, but they're just so that I can have speakers if I want them. I plan on getting some legit speakers when I have the money), and have so far been plugging them into the headphone out of the Matrix (they use a 1/8 inch plug for input, so I just slap on a 1/4 converter). I'm curious if it would be better to plug them into the line out on the back of the amp. I could buy an RCA to mini female cable and plug it in that way. Is that better? When the speakers are plugged into the line out, will the headphone out cease working? And if both do work simultaneously, won't that mean that only half of the amps power is going to the headphone out and half is going to the line out? I know nothing about amps' line-out functions and pre amps, so sorry if these were dumb questions.
Thank you,
I received the RCA > mini female cable I ordered from monoprice and my speakers do indeed work out of the pre-out at the back of the M-Stage. If headphones are plugged in, sound will come from both the speakers and the headphones at the same time. I'm not sure whether this means the output power of the M-Stage is split, and only part of the power is going to the headphones, but when I turn my speakers on and off with my headphones on my head, I notice no difference in sound quality so I'm fine with it.
Thanks again for the help guys.
