Low end. Cheap. Generic. Otherwise bang for buck cable thread!
Sep 29, 2019 at 1:28 AM Post #2,761 of 9,533
Please forgive my ignorance, but ive been following this thread for a little while now, but im still pretty new to all of this IEM and cable jargon. Ive seen people mentioning things like the 174, 175, etc, cables. Can someone tell me who makes these cables are so I can look them up and check them out? Are they available on Aliexpress?
Thanks!
Sep 29, 2019 at 1:37 AM Post #2,762 of 9,533
Thanks!
Sorry for the cryptic numbers. they are the numbers I assign to the cables after measuring and trying them, to distinguish and to refer to them easier than using a long description.
You can find these cables, measurements, comments, pics and links in my List of cables
Sep 29, 2019 at 2:38 AM Post #2,764 of 9,533
Oh hey, If I could have a few mins of your time, maybe you're the one who could help me with a cable upgrade issue I'm having, since you've got so much hands-on experience with so many cables! Ive been looking for a nice upgrade cable for my ZSX. But my choices are limited because my primary listening source is my Galaxy S10+. I have a very durable, comfortable and somewhat pricey case on my phone, which I love, but unfortunately it restricts the 3.5mm jack significantly.
For example, i bought the gold /silver KZ upgrade cable for my ZS10 Pro and that jack fits in the slot like a glove. I used some calipers to take a measurement. Its 8mm wide, which is the maximum width of a jack i can fit in there. I had previously bought a TRN T2 16 core cable for my CCAs, which i cant use with my phone because the jack is 9mm wide!
Also the length of the jacks differs. Iirc the KZ upgrade cable is like 18 or 19mm long, where the TRN is only like 15mm, which is too short to clear the depth of the case and fully plug into the jack. I've seen some jack styles that get thicker as they go towards the cord end. So a shorter jack could also cause clearance issues. Ive included a picture of my case situation below.
So, given that information, could you possibly give me some recommendations off your list of cables that you think might be a good fit for my ZSX and phone setup? I really want something better than the KZ upgrade cable. Something a bit higher quality and less delicate.
Sep 29, 2019 at 3:08 AM Post #2,765 of 9,533
check my list of cables for KZs, under $40 (they most are <$25). you can check if bevel in the jack by watching the pics or visiting the linked page, but not its diameter.
anyway, maybe you could sand the bevel to 8mm if it's 9mm. insert the jack (1cm, for example) into a drill, as if it was drill bit, and leave the cable free to allow it to roll a bit. put sand grit paper or similar touching the bevel. switch on the drill, slow velocity, forth and back.
edit: i forgot.. ZSX termination is QDC/ZSN/C-type (protruding socket). you should get that termination for your cable (QDC/ZSN/C-type encapsulated 2pins), or at least, flush (not protruding) 2pins termination, in order to get a firmer connection
Sep 29, 2019 at 5:10 PM Post #2,766 of 9,533
Hakuzen, I have browsed through your list until my eyes started to tear. Lol. Some level of dedication you have to compile that list man. Appreciate it. I am looking for an upgrade cable from my stock DM6 cable(silver- mmcx) to some good copper ones. Any recommendation? Something around 60-70 bucks would be a sweetspot for me. Anything of lesser or higher value might be something I would consider if you feel that it is worth that extra bucks. Thanks alot man.
Sep 29, 2019 at 6:24 PM Post #2,767 of 9,533
I've been recommending taiwan UP-OCC wires for last months, if you can afford it, because noticed a quality jump respect any other chinese wires I've tried. Bigger soundstage, and blacker background, which helps with imaging, separation, and detail perception.
If you are looking for copper wires, my best recommendation is cable 170 (4 cores) or 171 (8 cores) from my list (you can find them in part 1 of pics, comments, and links); my favorite copper cable (frozen up-occ copper litz, and superior quality plugs compared to usual chinese ones).
The perception of bass of DM6 will be slightly tighter, and better detailed, while keeping sub-bass rumble, and highs will stay there, not swallowed like with some cheap chinese copper wires.
I've not tried DM6, but judging from head-fiers' reviews and impressions, I'd bet this cable will pair DM6 perfectly.
Sep 29, 2019 at 11:02 PM Post #2,770 of 9,533
Have any of these cables been compared to branded, high end iem cables?
Thinking of getting 175
Branded high end iem cables use neotech up-occ wires, or similar quality branded wires.
From hificollective (UK), which stocks many reputed branded wires:
"Neotech specialise in UP-OCC wires, a high purity process for refining metals. Thus their product is a step above the rest. We offer pure copper and pure silver multistrand and solid core wire in Teflon sleeving. For all your wire needs."
Let me show you extracts of a private conversation with an experienced and wise head-fier (I got permission to post it here, while keeping him anonymous); they verse about cable 125 (extreme low resistance), and then, DIY cable made with VH Audio solid copper litz, and cables using neotech wires (165, frozen up-occ copper, 174 up-occ silver99%gold1% alloy [AgAu], 175 mix of AgAu and frozen up-occ copper litz, and DIY mix of AgAu with Cardas 23awg copper litz teflon sleeved); all paired with Campfire Solaris.
I thought his word is far more interesting than mine, because I haven't bought any of the very expensive boutique cables, and he has more accurate ears to discern subtle details.
"I remember talking to another member who owned extremely expensive kilobuck cables from Effect Audio. He bought cable 125 on a lark and was extremely impressed saying that he felt it didn’t disappoint coming from his high end cables."
"Your observation of conductivity not being the be all, end all metric is very interesting too. I found it interesting how differently cables 125 and 165 measured and yet you feel they perform similarly.
The guy owned Horus, Leonidas, and Janus among other things. Super expensive cables. I would never pay $1000 for a cable. That’s just insanity. But he did say he was surprised at the performance of cable 125 and said he didn’t feel disappointed coming from his boutique cables so that says a lot about how insane the markup is.
But yeah I was mostly interested in cable 165 due to the quality Neotech wires."
"I actually own two other cables that use genuine litz wire. I own a pure silver OCC litz cable from Norne Audio the Norne Therium and also a PlusSound Echo+ that uses type 6 UPOCC litz copper wire. Both cables sound notably different from my modified cable 125 (I just switched out the stock plug with an Oyaide platinum/palladium plug) while listening with Solaris. The Norne silver litz cable sounds very smooth with a bit of spotlighting on the upper mids. It sounds flatter in terms of depth, and noticeably dryer than cable 125. Depth is easier to perceive on cable 125, and it sounds meatier from top to bottom in direct comparison. The PlusSound Echo sounds very different from cable 125. Cable 125 sounds thick and organic, but still very clear, whereas the Echo sounds lean and analytical. Cable 125 reminds me of my Stax setup, whereas the Echo makes my Solaris sound like the old Sony house sound (Ex600, SA5000) which was much leaner, and more analytical compared to the warm, bass elevated sound they currently pursue.
That's the one thing that bothers me with cables really. I honestly don't notice the effect of cables as much on the majority of IEMs, but the impedance swings of the Campfire IEMs make cable rolling much more noticeable to me than anything else in my collection. I can actually hear/perceive differences between the Superlitz, Plussound Echo, Norne Therium and cable 125 because of this. Really curious to hear cable 165 now."
"The Norne and cable 125 feel close, but cable 125 has fuller lower frequencies as the sound stage and especially the depth feel more pronounced on cable 125."
"As for the PlusSound, the bass is quite a bit tighter, and leaner, and that has an effect on airing out the stage and making the midrange frequencies more pronounced. The sense of depth is even more exaggerated on that cable, and attack doesn't feel as blunted as on cable 125 which is more laidback in comparison. I'm guessing the PS cable must have a high degree of impedance or something vs. cable 125."
"Cable 165 with Solaris, there seems to be a slight bias towards low end frequencies. Bass is tighter than ALO's Superlitz and cable 125, those cables have more bloom and body to sub, mid and upper bass. Drums and bass lines sound and feel very nice with 165. With some tracks where the mix is thinner, it's a very nice cable IMO. Bass extension/amplitude is probably the best on 165. The body and note size of upper bass on VH is bigger than 165, but there's not as much emphasis in the mid and sub bass with VH, so drums don't feel as punchy as 165, but this gives mids and treble more room to breathe on VH, so it feels more balanced to me. You get more of a feel of the air around notes, and the harmonics in notes, Solaris sounds very open with it. You definitely still get very good slam on VH when the mix calls for it. I'm not sure if it's cause 165 is new and hasn't had much time on it, but it does feel noticeably more fatiguing than the VH Audio. Crazy thing about VH is that it's extremely transparent but never feels fatiguing to me. I can listen for extended periods of time to rough recordings and it's fine."
"The silver/gold neotech wire is supposed to be quite impressive after looking it up."
"Seemed like quite a bargain as the cost of the wire alone was close to $300 at about $16 per foot. I'm honestly sort of kicking myself for not picking it up."
Me: "is this the silver/gold neotech wire you mean?
https://www.hificollective.co.uk/wires/neotech-AG-GD-silver-gold-wire-teflon.html"
("New from Neotech, the UP-OCC 99% silver & 1% gold wire multistrand is the daddy of wire. Clear PE sheathed.")
"Yeah that’s the Neotech silver/gold wire. It’s referred to as AG/GD I guess. I found a lot of posts about it on speaker enthusiast forums. There's actually a guy in the cable DIY thread who made a headphone cable out of this wire. He seems to have a lot of experience with Neotech wire in general. He talks about the Neotech silver/gold wire here:
https://www.head-fi.org/threads/diy...comments-thread.676402/page-596#post-15004389
and here:
https://www.head-fi.org/threads/diy...comments-thread.676402/page-596#post-15011526
Sounds like it's a pretty impressive wire. A lot of what I've read about this wire seems to mention its ability to portray depth a lot."
"Sounds like an interesting wire, from a technical standpoint, but I'm always concerned about synergy, and find that copper tends to have the most qualities I desire. The build of materials would be very expensive, but I would imagine that a cable made out of components similar to my VH Audio cable using this silver/gold wire would likely sell for like $1000+ so I guess, it's not too bad considering the raw cost of materials puts you in the "midrange" of cables at about $325 or so."
"Oh finally I wrote that guy in the DIY thread about the Neotech AG/GD and he wrote me back. Seems the Ag/Gd may be god like after all, he thinks it's quite a bit better than the wire used by Effect Audio and even PWAudios's 1960."
"He tells me that the silver/copper hybrid cable he's made is really good, and has that oomph that is missing from the pure AG/GD cable."
"Saw your posts in the cheap IEM cable thread. WOW. The price for a ready made cable is outstanding! Unbelievable price for both 4 and 8 core."
"I have the cable built and have burned it in for 200+ hours just in case. I think the AG/GD cable sounds amazing in terms of midrange, space and detail. The sense of depth, openness and portrayal of transients is probably the best I’ve encountered so far, and it’s pretty much effortless in conveying the finest details however, I came to the conclusion that I feel it’s lacking body, decay, and ultimately realism. It’s a bit thin sounding, and lacks body/sustain in midbass and deep bass for me. The extension is quite impressive and listening to something like a glissando on a bass, it sounds effortless but yeah, it lacks some oomph/dynamics/emotion for me."
"So I ordered 23.5 AWG" (Cardas copper litz 23.5AWG)
"I think this cable is the one man. The OCC copper/AG/GD combo is honestly incredible. Amazing end to end extension, gigantic open stage, and hardly any sacrifice to the detailed, open sound of pure AG/GD."
"I don’t have the same issue with note thinness and lack of bass sustain compared with the pure AG/GD cable. The low end is full and tight. The sense of groove and prat is outstanding now. I think the sense of separation and depth is even improved. I’m not sure if this is due to the shielding of litz or because the improved low end is filling in the sound stage. I’m not sure how this Cardas wire compares to Neotech but I find it interesting that Cardas makes their own wire that’s stranded and bundled in a golden ratio spiral like Effect Audio."
"This hybrid cable is currently so dynamic and engaging to listen to. Totally hits all the right spots for me!"
Sorry for the brick.
But this shows another enthusiast of AgAu (wire of 174) mixed with copper litz (Cardas), a man with trained ears and large experience, together with some comments comparing expensive boutique cables to these.
I'm a confessed enthusiast of cable 175 (AgAu + frozen up-occ copper litz mix), but also of up-occ pure AgAu (cable 174), copper (cable 171), and copper+spc (cable 177), depending of what I'm pairing them with.
Sep 29, 2019 at 11:13 PM Post #2,771 of 9,533
and here:
Could you ask him to measure their resistance?
Sep 29, 2019 at 11:35 PM Post #2,772 of 9,533
Hey Hakuzen, much appreciation for the work you put into that detailed list of cables! Wowie!
I was going through it all and I have a question. I saw in the KZ section that you had tested the 8C Jcally and was wondering if you've tested this one at all? I didn't see it on the list. Ive kinda had my eye on it for a couple weeks now.
JCALLY Silver JC16 6N OFC 16 Shares 480 Cores
https://s.click.aliexpress.com/e/sTY8W0qy
Sep 29, 2019 at 11:56 PM Post #2,773 of 9,533
Hakuzen you should write a book!!
Sep 29, 2019 at 11:57 PM Post #2,774 of 9,533
Is it the believer that should test their belief or the non believer that should quench their doubt?
Sep 30, 2019 at 12:03 AM Post #2,775 of 9,533
+1
Come to think about it... yes, I had or bought more cable when I owned Campfire IEM and also more decent / better DAP...
edit : I can confirm you that SOLARIS is SOURCE Dependent, if you give better Eartip, DAP, music File, and cable, it gave different synergy... with compensation of HISS, dark background etc...
