Yes it is. Im a fan of pure copper cable, i will go for Gaia 7n occIs the second one satin audio?
Low end. Cheap. Generic. Otherwise bang for buck cable thread!
- Thread starter Dsnuts
- Tags
- aliexpress cable
CobraMan
- Jan 21, 2013
Okay - since nobody has done it I will: "Release the Kraken!"I liked specs of the Kraken..
Cheers,
Tim
SinisterDev
Hey all, so I know a bunch of people in the community use Aliexpress and ive recently hopped on the bandwagon too. Ive accumulated a bunch of coins and have been considering cashing them in for Aliexpress "Select" coupons so i can get a bit of a discount off a new cable upgrade for my ZSX. I understand that only some sellers accept this particular type of coupon. Has anyone come across any stores on there that accept select coupons towards their products? There's so many sellers of these cables and IEMs, its proving to be difficult to find one that accepts them, and they expire relatively quickly, so i dont wanna cash in coins unless I already have a purchase planned out first.
What I noticed is that the select coupon thing (where u exchange coins for) appears for certain stores during big sales (like the summer sale and 11/11 sales). It's not on all stores at all times. Sometimes there are time limited promotions where only certain items can be paid for with select coupons, but these are infrequent.
Occasionally if u are a new user or up a rank in Aliexpress or now and then they do give out aliexpress discount coupons (with minimum spend required).
But definitely don't cash your coins in until you are ready cause the coupons expire as u say.
Received the Effect audio Vogue line up cables. I know they are now cheap or bang of the buck. But the Vogue Maestro one is only 99$. I will post a detailed review of that Maestro one.
Cheers,
Tim
Somehow, it resemble like 175...
wish I had somekind of local seller like this...
MunchingFatCat
Hi guys!
Which cable would you recommend for moondrop blessing?
hakuzen
- Feb 9, 2016
I'm using cable 175 of my list with Blessing, and can't figure a better comboHi guys!
MunchingFatCat
Does it fit in the Blessing nicely? the last cable i brought was quite loose.I'm using cable 175 of my list with Blessing, and can't figure a better combo
or is there like any cheaper alternative i can go for?
hakuzen
- Feb 9, 2016
Yes, it does. The 2 pin connector needs to protrude to fit recessed socket of Blessing. This way you get a firm connection.Does it fit in the Blessing nicely? the last cable i brought was quite loose.
Standard protruding 2pins work perfect. Half protruding 2pins would be ideal (because Blessings sockets are not much recessed), less gap but difficult to find.
You can compare them in this photos (2nd is using angled mmcx->2pin half protruding adapter)
There are many cheaper alternatives than UP-OCC, of course, check the thread and my list. But for Blessing, I'd recommend UP-OCC cables.
hakuzen
- Feb 9, 2016
really nice cable 175! congrats!
MunchingFatCat
Alright,i am thinking of getting 175 (4-core).For the Blessing,which connector will better for the fit?
hakuzen
- Feb 9, 2016
G![]()
If you prefer metallic shell, A or D also work (firm connection, and 1mm gap).
MunchingFatCat
Alright,thanks!G
Total: 27 (members: 1, guests: 26)
