autosleeper
I’d like to try a pure silver on my DM6 to see whether they would indeed sound leaner. Could anyone recommend one at no more than $100?
What do they sound like now? I have mine coming. Waiting out to see what they sound like before getting nice balanced cable.I’d like to try a pure silver on my DM6 to see whether they would indeed sound leaner. Could anyone recommend one at no more than $100?
the cable won't change tonal signature by any means, regardless of its material and thickness. no tonal alterations.
i think the cable could affect to distortion/thickness, but this is still to be demonstrated. if this was true, you'd get slightly thinner sound with pure silver compared to pure copper or spc. useful for dm6 warm (means thick) sound; less bass rumble, mids body, illusion of lighter bass and more detailed mids and highs.
that's why i prefer pure copper cables for analytical thin sounding iems, and pure silver for thick (warm) sounding iems.
but you can't find decent thick pure silver cables <$20.
Hi, got BGVP DM6 IEM with the Copper & Silver Plated Copper (C & SPC) cable. Looking for an option that flatens the sound signature, equivalent to the stock Silver Plated Copper (SPC) cable.
Is there anything available on Aliexpress or Amazon USA for less or about $20?
I am overwhelmed by the many options in Aliexpress. Appreciate your help
check in this thread (not so many pages yet), some pure silver affordable cables which could fit your needs have been commented.I’d like to try a pure silver on my DM6 to see whether they would indeed sound leaner. Could anyone recommend one at no more than $100?
a cable won't lift those 2dB up in 1,2,4kHz. guess a good quality silver cable could make sound slightly thinner (although this is not demonstrated yet), helping to perceive mids to highs a bit clearer (but not louder compared to other frequencies).I have the DM6 with the hybrid cable and find that unless I eq up the 1,2,4 khz region by about 2db they tend to sound a little muffled. With the eq they sound quite good but was thinking of getting a silver cable... https://www.aliexpress.com/item/***...&terminal_id=a93eccb307ab4afca192b0e8039ae845 or I was also looking at this: https://www.amazon.com/gp/product/B07GZNQK9G/ref=ox_sc_act_title_1?smid=A267P2DT104U3C&psc=1
You think that either would clean up the sound a little? I would've gotten the spc cable but I got them off a treble-shy friend who ordered them with the other cable.
I can live with the eq bump as that seems to correspond on the freq charts with my other iems.
ps... i'm using spiral dot tips at present
the first cable you linked uses this wire:
7N OCC silver (gold painted) 0.05mm*48(27awg,OD:1.2mm)*4cores UV-PVC sleeve. expect around 240mΩ DC resistance per signal.
the 2nd cable is different; it uses this wire, probably.
99.9% pure Silver (not 7N, worse quality silver probably); TPU insulated layer of 0.05mm*50(27awg) + pure silver shield 0.05mm*45(28awg) OD:1.5mm * 4cores TPU sleeve.
they use shield layer for ground/cold signal probably. so each core carries 2 signal. this way, diameter for signal is equivalent to 24.5awg approximately. mine measured left+:137, right+:136, left-:131, right-:139 mΩ.
so for the same price, you get 2x thicker cable of a supposedly worse quality silver, in case 2 (btw, it's a neat looking wire, so shiny and soft..). you can choose between quality of silver (supposedly) of cable 1 or thickness of cable 2.
or you can go for the 8 cores version of cable 1, which is equivalent to 24awg, to get same thickness than cable 2, of a supposedly better silver quality. i'll receive this cable (8 cores) tomorrow. so shall measure it (expect around 128mΩ dc resistance per signal).
hope i can demonstrate different distortion (or any difference) in high quality cables, different materials, soon. nothing is demonstrated yet.
btw, spiral dots are a good choice for getting louder mids and highs, compared to lows.
thanks, you've given golden info about dm6 to me.Wow... great prices. I got my DM6 off my friend for what works out to about $165usd. He decided to keep the P4 Pro instead as he found the treble in the DM6 a bit much. We have very different preferences... I tried the p4 pro and thought them to be even less resolving than the DM6. I know that part of my want of a bit more in the upper mids and treble is due to my age and my particular hearing (we get tested at work each year) but in looking at the charts both my EE ESR and my Noble Savants have that lift that I eq'ed into the DM6. Maybe it's just one of those things where listening so long to a kind of signature gives one the sense of what's right over just what's familiar. I'm going to listen to the DM6s until I get used to them.. brain burn in... then do some comparisons. I use the DM6s at work and do notice that sometimes they sound so good that they approach that "uncanny valley" thing where the music "reality" conflicts with the external reality. It's the spatial cues thing... anyway,,, that's truly getting off topic.
I think I'll get the 8 core version of the **** and see what that does...
This quote is holding you to it.i'll measure and compare various iem cables as soon as possible (not only frequency response, which i already know it's not affected noticeably, but other parameters). shall post results here.
