Low end. Cheap. Generic. Otherwise bang for buck cable thread!
Nov 10, 2018 at 5:07 PM Post #166 of 9,541
Ya what is the difference in 16 core, 8 core to 4 cores? And does it really change the inherent sound characteristics of said material if you use more cores vs less?
If I was a betting man I would say probably not but who knows. If you want to get a 16 core to experiment and find out. You Carlsan would be a pioneer! For the sake of sound science!
Nov 10, 2018 at 9:01 PM Post #170 of 9,541
Pure silver from Lunashops.
https://www.aliexpress.com/store/pr...l?spm=2114.12010612.8148356.36.47811e2eFlP0CD $59
Nov 10, 2018 at 9:04 PM Post #171 of 9,541
That one will match the Solaris :ksc75smile:
Nov 11, 2018 at 5:15 AM Post #175 of 9,541
from my stock, cheapest one, great conductivity:
superb built quality (repairable plugs, strain reliefs..), very nice looking, good conductivity, a bit more expensive; various sellers:
the cable i posted above several times is more expensive, but you can find it cheaper at 11.11 if you make a search of "pure copper alloy" at ali.
it pairs perfect with toneking t4.
Where can I find that second cable on ali? I can only find the rebranded **** lookalike
Nov 11, 2018 at 7:24 AM Post #176 of 9,541
Nov 11, 2018 at 8:45 AM Post #177 of 9,541
Any suggestion for a MMCX 3.5mm balanced cable, around 10-20$ ? I'm planning to buy an F.Audio FA1, where the balanced out is 3.5, and I'm not sure which cable could fit it. Thanks.
I saw an adapter that will let you use a 2.5mm balanced to a 3.5mm balanced male. This is the way I would go if I was you. Simply because 3.5mm balanced is not common. If I find it I will link it. Then you can choose any of the more common 2.5mm balanced cables.
Nov 11, 2018 at 8:59 AM Post #178 of 9,541
Thanks. That's a great idea. In that case I would not even have to buy any 2.5 mm cable, as I can "reuse" the ones I have already.
Now the biggest doubt: shoudl I buy a Zishan DSD PRO or F.Audio FA1 ?
Nov 11, 2018 at 9:06 AM Post #179 of 9,541
Nov 11, 2018 at 10:29 AM Post #180 of 9,541
You plan on using iems or headphones. reason I ask is I read on the Zishan thread that those players have high impedance out. Which will change sound characteristics with more sensitive IEMs. I believe @hakuzen can help here.
So this is the only place you can find one of these. This is from Penon. You can choose a male 3.5mm balanced to female 2.5mm https://penonaudio.com/accessories/earphone-adapters/silver-plated-hi-fi-balanced-adapter.html
Thanks Dsnuts. I bookmarked the Penon's adapter, in case I go for the F1.
I will use the Zishan DSD / F.Audio F1 exclusively with IEMs (DD or hybrid), that's why I'm a bit sceptical about Zishan (based on hakuzen's posts in the Zishan thread). On the other side, the F1 has the small drawback of the 3.5 balanced output and the bigger one of click between songs (and no firmware on the way... Xduoo-style). I will keep on thinking about these players the next few hours :-)
