LG V20 Sound Quality
Sep 5, 2016 at 4:12 AM Post #78 of 4,141
The phone won't be modular, the bottom is removable for both the battery and the SD/Sim card access.
Sep 5, 2016 at 4:16 AM Post #79 of 4,141
The gain setting is a PIA on the V10 and it is a legitimate issue for people who use it with other than IEMs, let's hope LG wised up on this issue and stop catering to the lowest common denominator. :mad:
Sep 5, 2016 at 4:21 AM Post #80 of 4,141
The 2V output will put it roughly in equal company with the Audioquest Dragonfly red.
Sep 6, 2016 at 3:05 AM Post #82 of 4,141
An interesting analysis of the DAC in the v20
https://www.google.com/amp/www.androidauthority.com/lg-v20-quad-dac-explained-713587/amp/?client=ms-android-hms-tmobile-us
Sent from my SM-N930T using Tapatalk
.... Good info Link. What i want to see (and hear) if the V20 Could play back 6 channel audio.... Still my V10 days could be numbered...
Sep 6, 2016 at 9:01 AM Post #83 of 4,141
So, is this thing expected to be able to power something like an HD 800 or other 300 Ohm cans?
Sep 6, 2016 at 9:10 AM Post #84 of 4,141
It will power them to decent volumes but it won't drive them well. My LG V10 drives the HD 700s decently as well but a dedicated amp leaves it in the dust!
The V20 will have 2V lineout so if you hook it up to a higher power amp it will drive it better for sure! The V10 I believe has a 1V lineout and I always had to max out my amp to compensate . so it was far from ideal.
Sep 6, 2016 at 9:58 AM Post #86 of 4,141
Sep 6, 2016 at 12:23 PM Post #88 of 4,141
The latest leak says QHD LCD and a 4000mah battery is also mentioned which would be a real step up from the V10's 3000mah. Not to mention the 820SOC which is leaps more efficient than that clunker 808 in the V10. So if LG don't screw this up they could have a real powerhouse in their hand.
Sep 6, 2016 at 1:35 PM Post #90 of 4,141
OLED screens for smartphones, which typically and frequently used for web browsing and display image with white background, isn't a good idea. I choose LCD over OLED any day on a smartphone.
