- Aug 2, 2008
^ Just curious, have you yourself heard for any extended period of time any of the "overkill" amps in a good setup with matching upstream and downstream components?
If I made a thread in the Sound Science forum about "Overkill amps", would you participate in discussion? I've been meaning to anyway, what with all the talk about the Objective2 amp.
May be this is late and out of context here.
I recently have my LCD2 rev2 ( I also own LCD2 rev1). LCD2 rev1 does not have the problem with bass impact
and quantity but the dynamic and decay are relatively slow. LCD2 rev2 is different , definitely less bass but more open
sound stage and no treble roll off. However when I use a good amplifier (in my case it is eddiecurrent 300B new Balancing
Act), I am using the KR PX4 or AVVT 32B as power tubes. The standard driver tube is tungsol BGRP. The bass of LCD2 rev2
is adequate. However I recently changed the driver tube to Sylvania 6SN7W metal base long bottle, that changes the whole
scenario. LCD2 rev2 has a lot of good quality bass, impact quantity dynamic decay slam extension of the bass are excellent even
the bass dynamic of LCD2 rev1 also improved. Please try a good amp with the Sylvania metal base, I also use apuresound V3
and Zeus silver clad cable you will be surprised about the bass of the LCD2 which is one of the best. For the LCD2 I do think
you do need a good amplifier, good recable, good tube to make it shine. I am still surprised too with the electronic music of Deadmau5
: for lack of a better name, Rock music by Nickelback (greatest hits) , Muse (the resistance), and music of Black Keys : Brothers etc.
Good to see you finally got your ECBA! I hope you are enjoying it and rolling all sorts of 6SN7 tubes.
Anyways, back on topic.
I'm wondering here if there is confusion in this thread on whether the OP's complaint of "weak bass" is with lack of bass volume or lack of bass impact, or both. Sure the LCD2 is relatively easy to drive, but I've found it (r1) rather dull and not every open with lesser amps. With the better amps, the LCD2 sounds more effortless and relaxed with a ton more slam (we're just talking in the context of bass here,) but not necessarily more bass volume. It's not a power or wattage thing either - the ECBA only rates at 1.5 W into 32ohms (I don't know how it got turned into a power thing in the first place.)
Now I haven't heard the Dacmini, but it sounds like the OP may have just had different expectations of the LCD2's bass.
Originally Posted by nieveulv /img/forum/go_quote.gif
...However is the sound of the "bass guitar" that i found to be totally lacking in volume and impact...I feel i need to focus too hard just to hear the bass guitar sound for rock music.
^ Sounds like a mid-bass bump volume thing. No mega-buck amp is going to help you there. It's just the nature of the headphone. I'm with you though - I prefer a mid-bass bump myself, but only very slight.
Try EQ +3db at 100Hz.
will a digizoid ZO portable subwoofer help? And how do you reckon i can connect it to a DACmini/lcd2 setup? I heard combining 2 amps is never good..
http://www.head-fi.org/t/504037/mini-review-digizoid-zo-portable-subwoofer
http://www.digizoid.com/the-zo/
I think this is designed more for bass lovers on the go. Some of the best affordable IEMs are relatively bass-light, and bass is the first thing to go in a noisy environment.
You should try EQ first. That's free. What program are you using for playback?
