EQ-ing the LCD-2
well, after doing a bit of venting, and nearly giving up and selling my LCD-2's in the process due to their anemic bass.. yeah i said it...
![Wink :wink: :wink:](https://cdn.head-fi.org/e/people/wink.svg)
I have finally after nearly 2 weeks dialed in an EQ setting that i feel is nearly universally appealing for all music genres.
first a few notes - I have had TONS of practice eqing headphones via sine waves / rolling frequency sweeps. I have done many a/b comparisons with stock headphone sound vs eq'd "flat" and my goodness you woudlnt belive how imbalanced most cans are, and how much they can be improved.
The idea is usually to get all frequencies to sound the same volume, or close to it.
obviously this setting does not make the bass sound the same volume as the other frequencies, however to my ears, it ads the missing bass and makes the music sound "right" no bass bloat, or covering up other frequencies, or ... blah blah blah... i admit its probably a little bass heavy for some people, but to me this sounds great, and is a far cry from overdoing the bass/sub bass or eye shaking.. which by the way the LCD-2 can be eq'd to do like crazy.
after using this setting for quite a few days, its interesting to go back to flat and hear, not only that the bass was clearly lacking to the point of major parts of the music not being heard, but that there was some clear sibilance happening.. though not much, but certainly enough to explain why these cans felt strangely fatiguing when i first listened to them.
my rig = ipod touch 4th gen, lossless files, "equalizer" app - LOD - RSA SR71B - balanced out - LCD-2 r.2
frequency settings from left to right
+3.2 @ 23hz Q. 3.0
+10 @ 67hz Q 1.0
-3.6 @ 99hz Q 0.8 - this is only in place in order to flatten the frequency response starting at 100hz that gets pulled up by the previous setting.
-2 @ 605hz Q 1.0 - evening out a slight peak here
+0.5 @ 1534 Q 0.8 - to bring the curve up to flat where it is being ever so slightly pulled down by the 2 settings surrounding it
-6 @ 3500hz Q 1.5 - evening out a larger peak here
+12@ 8300 Q 7 - my cans have a dead spot here. (actually a very common phenomenon in headphones though not always in the same spot) this fixes it.
and most importantly - set the pre-amp to -12 to avoid any chance of distortion (could probably be at -10 or -10.5, but this setting is touchy on this app, and -12 was close enough)
