DonS1000
- Apr 11, 2016
I believe this is known issue with ESP 950. They have lifetime warranty though.
I have my 950's runner off of a SRM-1 MKII in pro bias and I can confirm that it is much better than the E-90. Much better.Yes they do. They need bias supply (600V, which is a scooch higher than the STAX Pro bias (580V) but from what I've read/been told they will play along with 580V just fine), as well as high voltage drive for the stators (the E/90 is able to do something like 2300Vp-p). That's nothing a "conventional" headphone amp can deliver or even connect to.
Can I connect my cayin i5 to the srm?
I've been moving stuff around so I don't have the Yggy hooked up right now and was running it with my QP1R sounds pretty good also.Can I connect my cayin i5 to the srm?
That's what I thought as well...unless you could find an energizer like the SRD-5 on the used market or we're willing to shell out $500 for a Woo WEE. Gotta love that name!![]()
Got my eBay-fresh 950s this morning and have been listening for about 5 hours now. I have it hooked up to an Oppo HA-2, as my Marantz HD-DAC1 is still inbound.
Random thoughts in comparison to Hifiman HE-400i (only other phones I've been actively using as of late):
I love the immediacy and clarity of the 950s compared to the 400i. It's as if a curtain/veil has been raised.
The bass isn't as prevalent as it is on the HE-400i, but that isn't a bad thing. It seems more controlled/refined.
The 400i's soundstage is considerably larger than that of the 950. If there's one aspect of the 400i I could "blend" with the 950 thus far, that would be it.
It could be the newness of the 950s (to me), but I find them a bit more fatiguing than the 400i. Might just be an adjustment issue.
950s are very light, very little clamping force.
Microphonics... UGH! Every time I turn/move my head I can hear a crackle/rustle. I think it's physical, as opposed to anything wrong with the phones themselves. I may get some new pads from Koss to see if that fixes it (and possibly to mod... at $5 per pair, kinda hard to go wrong).
Split volume knob can be a bit annoying. I've put some scotch tape across the two knobs to tie them together so that I don't unintentionally fark up the balance when I go to change the volume. I think that when I get the Marantz I'll use the variable line out and use the volume control on the Marantz and just leave the knobs on the E90 in a fixed position.
Overall, for just under $350, I'm quite pleased... will take some adjusting, but I like what I hear.
I hope to get my first shipment on or around 2/27, but since they're all hand made, they can't crank them out in any kind of quantity.
You can preorder them now from us.
So far the first few pairs are already sold though. But I don't know how many I am getting in each shipment.
Sure. You can pre-order here.
My ESP 950 have almost stopped me on my ultimate headphone search.
I use an Idecco as my DAC and the Lyr amp and this setup is one of the best headphone setups I have ever heard. Yes I have listened to a Stax 007 and Stax 009 for about 20 minutes each.
The ESP950 with the energizer unit alone is great but not even close to my current setup.
I am extremely thrilled with my current setup.
First shipment of pads arrived today. Only two pairs available after the pre-orders.
