I haven't followed the Chi-Fi releases in a while and I'm looking for a new set of IEMs. I would like to purchase something with a similar fit to the KZ ZSN/ZS5 (as the KZ ZS10 fit me rather poorly) but with a better soundstage and overall better audio quality. Would the KZ ZS10 Pro or the KZ ZSX Terminator be good IEMs in my situation? Or do you have other recommendations for other KZ IEMs or even other brands?
KZ ZSX Terminator are big potatoes in your ears.. my first iems and havent used them ever..i dondt care about the sound if i have a potatoe in my ears
Also i hate those 2 pin things
You are missing out. I just put on the Radio Shack medium tips and they added even more than the Starlines. The ZSXs are amazing sounding, even notwithstanding the price.
ok so nice to know i should give them a more love.. just need an adapter for mmcx because i dondt want to use the potatoe cables that i got for this... well i wont buy adapters.. sorry KS ZSX.. press "F"
I am just so happy with Tin p1 and Shuoere Tape (i cant spell this stupid name.. sorry.. never works ) that can be driven to the mars on my E1DA PowerdacV2 and 9038s mobile
Well they wont run away those KSs
I guess with some eqing they cold be really nice too.
It's pretty awesome. I was driving mine with the ES100 and a nice balanced cable (probably from the banned company), but since I got my R5, I swapped out for a 4.4 balanced cable and they basically haven't been unplugged for very long. The ZSX doesn't mind more power at all, but you'll have to notch the volume down at least a little. On the R5, I have to turn it down a lot.
But the ES100 and a balanced cable will make for some happy ears.
Going to balanced on the ES100 you might hear a better stereo separation, but with an already wide soundstaged IEMs the difference might be minimal. Power-wise, i reckon the ZSX is similar to the ZS10Pro, so going balanced for more gain won't be necessary.
I usually use balanced on the ES100 for my high impedanced earbuds/headphone, or for IEMs that's more center focused soundstage.
I will try to help you out but I need some more info from you. First of all...what kind of genres of music do you mostly listen to? There is NO SUCH THING, as an earphone that "does it all the best". If you only listen to a specific genre or certain songs, it's easier to find the one iem that gives you the most enjoyment from that genre or select set of songs. If you like multiple genres (like I do), then you might wanna get several different sets to use when switching genres. Also, you don't mention the kind of sound signature that you like. Do you prefer bassy and warm, or highly detailed but more subdued in the bass? Forward midrange or laid back? Detailed treble or smooth with a big soundstage?
