phower
- Apr 28, 2013
Yes. I have replaced capacitors on PCBs years ago.Well, imo it is easy but it all depends how much experience You have with soldering iron? If none, then better let someone else do it as soldering driver requires low-wattage iron and very short/fast soldering job to not damage driver by heat conducting over coil and membrane wires.
Fixing and installing mmcx sockets is quite "plug-and-play" but it is recommended to use gel-superglue to fix it securely inside shell.
What wattage for the soldering stick? 30/45/60 W? I already have the plastic pry tools for opening. I just have to order the MMCX connectors.
