Viber
- Jan 28, 2008
KZ 1week old foamies...
Happened to me a few times as well, you probably need foams with larger holes.
They're rubbish! I also used those foams once, in the only IEM they fitted properly, the MEE M9. Never had good results with any other IEM.KZ 1week old foamies...
I don't get severe irritation from the upgrade cable, but it does rub occasionally and I've been pondering throwing a piece of shrink wrap without a memory wire over the same area where the memory wire used to be.
Haven't done anything about it just yet though, so it's still just an idea in my head thus far
Buy a green pair and a black one, switch the fronts, sell the one you like least.
Don't happen to have a supplier in mind for that stuff, do you?
On a quick search I can't seem to find quantities less than 100 feet or so.
I did a lousy job of searching eBay apparently...
One thing amazes me with the Chinese phones, you take them out the box, and they generally fit, without any other mods, whilst with other well known makes I have spent weeks trial and error, ah well.
I dont use foamies much in the past..
didnt know there are gelfoamies.. fakefoamies with bones..
yes..n the real complys
U guys are EXPERTs..thanks!!
Was quite happy w spiral dots in the past... couldnt find a pair in my dusty candy cans.
That doesn't make any sense?Possibly because they design it primarily for the chinese / asian market, who anatomically might have smaller ear cavities, hence when exported to other markets, they have less fit issues, as generally, they are smaller in size ?
I'm guessing it's the other KZ upgrade cable that's been out for a while now based on the same overall braid and terminations, and that the lighting is causing it to look a little different, but I could be wrong. Available on Amazon here (which might not do you any good, but maybe for others?) https://www.amazon.com/dp/B074H8Y76X/_encoding=UTF8?coliid=I3TBALX3LF68RC&colid=1KLURIQMSZMYE or AE here https://www.aliexpress.com/item/New...e-Earphone-Upgrade-Cable-for/32819485018.html. I have this cable as well, but didn't have the greatest fit on ZS5/ZS6 (obviously others have had better luck), so I only use it on the ZST/ES3. Flexibility is very good, it came with memory wire which I removed. So far it hasn't started to turn green yet, but we shall see. Despite the titles saying 0.75mm pins, the cable I received was 0.78mm pins, which makes sense since they are advertised for the ZST (purchased from the second link). I mainly purchased for aesthics, and don't personally notice too much different in SQ (if at all).How much was the cable and how is its flexibility?
