  1. Lord Rexter
    Sounds cool will try it out in the weekend. Thank you :ksc75smile:
    Fox2twenty likes this.
  2. Adide
    See my edit for disclaimer though.
  3. Lord Rexter
    Your disclaimer was interesting so went ahead and did the mod, well someone had to try I thought better be me :o2smile: it's working good and looks slicker too. Thanks again.
    hakuzen, Fox2twenty, Superluc and 4 others like this.
  4. CoiL
    What cable are u using?
  5. Lord Rexter
    Fox2twenty and HiFiChris like this.
  6. CoiL
  7. TJK81
    Recommend not to do it this way. I will make a photo to my silver plated 45deg. cable for ZS5. I patientely modify the connector to not to cut it completely off. But only to adjust the connertor to fit it directely to my ZS5. I will do the same to cable for my upcoming ZS6.
    EDIT: Photo attached 20171019_202616.jpg
    Slater and Adide like this.
  8. oyobass
    That cable looks amazing with the metallic green.
  9. Slater
    Looking forward to see what you modified.
  10. Spelaeus
    Just did this to mine late last night. I can confirm that the housing is deep enough for the pins, and connection isn't any less secure. The only problem now is that it's much harder to verify proper polarity when plugging in the cable since you can't match the curved edges anymore. I may have to find some way to mark orientation.
  11. Lord Rexter
    I tried the cable on ZS5 v1.0, ES3, ZST and ZS3 all work good and look great see pics
    hakuzen likes this.
  12. thejoker13
    Well, my zs6's finally arrived after a 2 month long wait and......they're not for me. Would anyone be interested in buying a kz zs5 (version1, gray) and a black zs6? I would include a non mic cable, a mic cable and 1 silver upgrade cable along with the 2 iems. I was thinking somewhere in the 50.00 ballpark for everything. Pm me if anyone is interested.
  13. Gianluigib
    Hello guys, i bought the bgvp dm5, is it a step above the zs5?? Thanks
  14. bsoplinger
    Interesting to see you're using foamies on all your KZ earphones. I only have the ZS5 and couldn't find a foam tip that felt comfortable. So I'd like to know what you're using. I just, as in I've just sat down after getting the mail, gotten my gearbest package with a pair of ZS6 and the KZ foam tips along with the now older white colored silver upgrade cable since I didn't know that there were other cable choices when I ordered a few weeks ago.
  15. Mellowship
    The new kz copper cable is nice. Just got mine. Already took off the useless wire.
    Saulo Jonas and F4yze like this.
