FunkDrummer
- Dec 21, 2013
That review was good enough for me
. Thank you so much! I'll check Jokers review now
Personally I'm using the Soundmagic Double Flange tips on the FXD80. If someone has a pair just of soundmagic double flange, you should try it out on the JVC FXD/FRD80. It doesn't help the sound quality much, in fact, it even removes some bass rumble. But it seemingly improves the midrange and spaciousness. Plus its both comfortable and seals properly. With stock tips on my small ears, its comfortable and the seal keeps getting disrupted.
Is it possible to use tips from maybe the EPH100 or the Audiotechnica CKN70? Those are nozzle mounted microdriver iems too.
I'm guessing any tip with a wide enough bore work.
Huh, interesting. Getting tips to fit is one of the trickier parts of the FXD... Nice to know the Soundmagics cut down on the bass a bit, could be worth a try... but I'm probably just going to sell off my FXDs anyway. If nobody chimes in by the time I get home tonight, I'll try fitting the EPH tips...
The FXD70's and 80's have weird size nozzles which is extra large. The EPH100 tips would probably fit, though I never tried them on the 80's when I owned them. I did manage to somehow fit some sony hybrid tips on them and they were by far my favor tips. You can give them a try if you have some hybrid tips. The stock tips weren't very good and complys muffled the sound for me.
Let me know what the verdict on the EPH tims is.
Take a thin needle and poke some hole on the white filter that's on the nozzle and hear all the glory of the fxd80 plus use the Sony hybrid tips
hmm.....I wouldn't suggest poking holes in the filter. but hey, what do i know? also, im pretty sure that the driver diaphragm is directly behind that filter. wouldn't want to go poking holes in THAT now would we? or is that just another technique that enthusiast have developed along side 500+ hours of burn in..... I'm pretty sure JVC has engineers...
