Tom22
- Sep 3, 2012
I recently bought these for a friend, but she is having trouble with the fit. The stock med. silicon tips start slipping out after a few minutes, and the small tips are too small. Any suggestions on what she should buy?
I saw these referred (http://www.amazon.com/Bluecell-Medium-Eartips-earbuds-earphones/dp/B007BWCDYQ/ref=sr_1_3?ie=UTF8&qid=1374765603&sr=8-3&keywords=foam+tips) in earlier posts. If that's the best option, should she go for the small or mediums?
Any other recommendations would be great!
i'm assuming you have the fxd80 , not sure if the other versions tips are different
your friend tried all the tips? even the large ones?
