EagleWings
Unfortunately, it didn't help I've loaded my LPG 256GB card with 150+ GB of DSD, but everything I see on the screen are 11 tracks from one of the catalogues and no ability to go up in the catalogue structure, as if this was the only album on the card. Any ideas...?
Yep, mine does the database update and choosing this option again doesn't help I have a 32GB card with some of my DSD albums and it WORKS. It only doesn't on 128GB and 256GB card. The 128 and 32 are even exactly the same type and company (Sandisk)! Maybe I'll try deleting the DSD files and use only FLACs and will see what'll happen...
I wonder if the format of the SD card might have to do something with it. I forgot what format the SD card in my LPG is, but I can check later today evening and get back to you.
Or check what format your 32GB card has and you could format the 256GB card to the same format.
