For the Zenith? I would recommend a smaller bore tip such as the Final Audio. The Final Audio is the tip I use with the Ares II and Black filter.Hi guys,
Any recommendations for eartips? I'm having fit problems with the bundled eartips and for now the best fit is with some New Bee memory foam tips I use with the Tin Audio T2.
IMR - R1 Thread
- Thread starter AudioJunki3
weexisttocease
Arguably the toughest thing to figure out with the R1. I'm still on the search for the perfect tips for my ears and I've had the R1 for a long while already.
I've tried tons - Spinfits, Spiral Dots, Symbio, Flare Audio.. you name it.
Currently the best I've found are ML Spiral Dot for their wide bore and overall fit, however I still find them a bit too soft and they are hard to get to sit perfectly. For foam, the Flare Audio tips are really nice, though I ordered a set thinking they would fit me but are a bit too big. I think the Flare Audiophile tips could be a winner as they sit well and also have wide bore. In my experience any of the tips with smaller bore tend to tame the R1 a bit too much, though not sure about the Zenith (you didn't specify which you were asking about).
I was planning on grabbing a set of comply tips this weekend, and also waiting for Symbio to restock on their Large size Symbio W to give those a shot as they appear to be a good option.
Thanks for the reply.
I have the Zenith since last week, it's my first proper pair of iems but as I said before it's been difficult to get a good fit, especially with my left ear. I've only used so far the black filter as I want to get a good fit before testing the other filters. I'll give a try to Flare and Symbio. I really wish the the Zenith had the same fit of my B400s because from a few listens it sounds really good.
weexisttocease
Spinfit or Final Tips. this always works for me as far as silicone goes.
If you want foamies, then Comply is the most popular, and there's also mandarin tips that are quite awesome, as a hybrid.
Thank you very much. I'll buy a few if I can get a good fit.
weexisttocease
Thanks. Where can I get Final Audio tips? I was about to buy the E5000 but the Zeniths promo code was too tempting.
Sito Lupion
- May 14, 2016
For me, New Bee foam tips made the magic of the fit. They are very comfortable and cling to my ears like a child to his toy when you try to take it off...
They are also cheap, 12 tips for less than 10 dollars are a good buy.
I am using blue filter and the sound is fantastic.
I’m finding either the final audio Es or the symbio MandarinEs both to my liking with the Zeniths.
bogginhead
Banned - AKA Lee McDonaldUnreturned Tour Gear, Sells Borrowed Gear, Incomplete Trades
Anyone here possibly willing to trade some Flare Audio Audiophile earfoams for some Symbio W's? I'd be looking for medium in size. i've got about 6 new pair of W's in medium and a pair of the smaller bore in the same...
weexisttocease
cleg
- Oct 14, 2011
My text review of R1Z: https://porta.fi/imr-r1-zenith-clinching-the-victory/
Russian version: https://porta.fi/ru/obzor-naushnikov-imr-r1-zenith-zakreplenie-uspeha/
Great review and pictures, Paul. You do good work.
I decided on nozzles (Pink r1z/Green Icarus III) and tips (Final Es) what is the choice cable for the Z? I’ve got an Ares II on order, but was curious what others are using? Oh, while I’m asking, what dap/set up are you pairing with them also? I’m pairing with a QP1R at the moment and it rocks!
The QP1R is a great DAP, from all I have read and judging from my QP2R. I also like the DX120 pairing and it won't break the bank. Also, the Ares II is a great purchase, it pairs so well with many different IEM's, I think you will really like it.I decided on nozzles (Pink r1z/Green Icarus III) and tips (Final Es) what is the choice cable for the Z? I’ve got an Ares II on order, but was curious what others are using? Oh, while I’m asking, what dap/set up are you pairing with them also? I’m pairing with a QP1R at the moment and it rocks!
bogginhead
Would anyone on here wanna trade some Flare Audio Replacement Audiophile earfoams for some Symbio W's? I have 6 pair or so in Medium, and one small bore Symbio in small. All brand new.
13gsc13
- Feb 13, 2013
I just obtained a used pair of acoustic R1
I read thru every post and based on everything everyone said I bought them
I have them on the orange filters and foam tips and they sound fantastic to my 61 year old ears
Thank you to everyone who posted good and not so good things about them
Gord
Gord
BigNewsII
@13gsc13 Welcome to the IMR thread Gord!
