I don't think anyone in this thread (or any E10 thread) has proclaimed E10 as an absolute upgrade to any other soundcard, on-board or external. Hype is where someone is blindly believe in one product and trying to convince / mislead others to believe so, and so far I don't think that's the case here. I certainly believe there are other much better sound card out there. But just like any review, you can't assume a product is going to be great just because it has found to be great for 99.99% of all the user (*just a figure of speech, which can be any number). You'll never know whether you are the 0.01% or not without trying out for yourself. If you simply doesn't think E10 has done it for you, I'll suggest you to return or resell it and perhaps move on to something better. There is no point of dreaming that burn-in will magically make everything better.
[Impression] FiiO E10
- Thread starter ClieOS
mogwhye
- Apr 12, 2012
Thanks for your replies Papander & ClieOS.
I've seen a few posts here and elsewhere, where an E10 has not yielded any improvement
in SQ over an onboard Realtek card. I've also seen posts claiming night and day results.
With such a subjective subject, as ClieOS rightly says, you have to try it for yourself.
I've got a 30 day return policy, so I'll give it another week and then make a decision. Perhaps it will burn itself in by then !
I'll then decide whether to try another (more expensive ?) DAC or maybe I'll try an upgrade to my HD-497s instead.
vampy
- Apr 13, 2012
I got my E10 today, i really like this little sweet Monster xD
Before i had a Creative X-Fi Music with a solderd [size=x-small]LM4562 opamp. [/size]The E10 sounds a LITTLE bit better.
Pros: cheap, little, nice sound, great design.
Cons: no mic input, headphone in is awry, bass boost button (What there should be a mic input instead), "short" usb connecting cable.
Edit: headphones -> DT770 250 Ohm
RealSlimSeto
- Sep 13, 2011
Any more inputs of how the E10 sounds compared to a onboard Realtek soundcard?
Fizz
- Jul 5, 2011
Honestly I'd really like to reiterate my experience with it versus Realtek.
What I found switching over using the DAC side to power my speakers, I found a low end that was more detail but only slightly stronger, while I found that I was then able to turn off my equalizer in Foobar 2k and get my mid range back into the music. The highs were no longer as harsh as well. It more or less just made things more controlled.
The difference wasn't night and day, but it definitely made a difference.
tattare
- Apr 17, 2011
The people that just got theres can you post a picture of the front of it? really like to see if they changed the jack yet.
mogwhye
- Apr 12, 2012
tattare - the E10 I got in the UK last week looks like this
http://cdn.apple-gadgets.de/wp-content/uploads/2012/02/fiio-e10_008-584x328.jpg
The headphone jack is silver and metallic.
LoveKnight
- Nov 23, 2011
Then I could say that Fiio has not changed the Fiio E10s' design yet, because they announced that the headphone jack will be gold instead of silver in reversion 3 (i think).
Very sorry, reversion 1 has silver RCA jack. reversion 2 has golden RCA jack, reversion 3 has not released yet.
Tu13es
- Apr 10, 2012
mp4nation is saying they have the 3rd revision...?
I think they think the first batch as revision 1. but it is not.
tattare
- Apr 17, 2011
I thought I read somewhere that it was going to be a plastic jack. Ohh well we will find out if rev 3 ever releases.
sunnymushrooms
- Nov 9, 2008
EDIT: Found out what it was *slaps forehead*
For those who are newb like me, basically go to "Sound" on System preferences, click the Output tab and switch the device.
Cheers Everything sounds good.
ricerocket
- Apr 6, 2012
Just got mine. I got some pretty wicked distortion out of it no matter if it's on headphones or into my home amp. I recorded this from the line out to the input on my Mac.
http://soundcloud.com/jimmy-5-3/What-fiio-e10
Pretty safe to say it's broken, right?
It's a 1st gen btw.
It's a 1st gen btw.
It's a 1st gen btw.
Not necessary. I have an incident where E10 becomes distorted after a computer crash and restart. Everything seems well except the audio driver was corrupted and E10 will distort all the time. Once I reinstall the driver and restart the PC, everything went to to normal. The quickest way to check is to try E10 on different PC and see it will distort or not. If it doesn't, then the problem is in your PC.
