Is anyone else hearing static and channels cutting out when they move the headphone jack? If I bump the jack when changing the volume it causes static. This is happening quite often. I was wondering if this is an isolated incident or if they are all like that. I would hate to return it and get a replacement that also has this problem.
1, When changing the volume knob, it may cause some noise, it is decided by the potentionmeter.
2, For the headphone jack, when you moving the connector, it may also cause the noise when the connection is loose.
For the noise of potentionmeter, it is made by Alps which is the best we can found now. of course digital volume control can solve this problem. but lots of people may still like potentionmeter.
For the headphone jack, there are not any evidence that the same jack which used in our E7 will cause big problem, so far the defective rate is very low, and we already sold out so many E7, it had been proved that it is a reliable jack. of course, compare with the jack which we used in our E6,
the jack used in E6 will be more tighten, but the question is since it is so precise and small, it is more easy to be damage.
Anyway, we will make more research and try to make it better . thanks for the report.
