Ah, I apologize, Google found it and I didn't even check if it's already published or not.
Would the iDAC2 be preferable to iDSD Micro or Nano for use in a desktop system: computer's USB3 > iDSD2 > integrated amplifier > speakers or rec out to Bottlehead Crack amplifier > Beyerdynamic T1?
I will not use the DAC on the go, so I'm not interested in battery power. I know the iDSD uses 2 DAC chips, supports higher formats (which I don't intend to use for quite some time) and battery only power should be cleaner than USB one... But is the difference in sound quality high enough to justify the price difference?
Hi,
Hey, no apology needed. Nice catch. The iDAC2 webpage needs to be ready to go for mid-June when it is launched.
For a desktop system, given you have no need whatsoever for a portable system, then the iDAC2 is the better way to go.
Think of it as:
micro iDSD = BMW X5 SUV (Costs £££££): can do anything, go anywhere. Yet carries 7 people and a load of shopping.
micro iDAC2 = BMW 530D (Costs £££): saloon, plenty of space for 5 people, motorway cruiser all day long.
So if you say I sit on the motorway all day long or in this case, dont leave the house, then we recommend the iDAC2 as it is best suited to your requirements.
We'll update the iDAC2 thread in the next day or so with more technical information. But below is a little tech info.
Technical Info
Where the iDSD micro was targeted (and primarily crowd-designed here on Head-Fi) as portable and headphone centric product, the iDAC2 is targeted as stationary use.
The iDAC2's line out quality matches the iDSD micro, but due to the Class A buffer it offers better compatibility with difficult cables or low impedance loads (it can drive 600 Ohm pro-audio loads without problems).
Cetris paribus, in terms of ultimate SQ, there is not much between them. Same will say iDAC2 is better, some will say micro iDSD is better....but for a pure desktop rig, just like at Munich, we did iDAC2, iTUBE + iCAN.
But we also had micro iDSD available for instant demo and people brought their own IEMs and plugged in their phone.
