curentatu
- Nov 19, 2016
im curious about the SmartPower charging port on the micro Idsd BL, if you plug in a 5v charger in that port, will it charge the micro idsd BL itself ?
Had the same thing yesterday - LED was turning green, then white, right after power-on, and the PC wasn't seeing the DAC connected. I pulled out all the cables, flipped all the switches, powered on the Micro disconnected from everything, saw it get to the blinking-green I was hoping for, then powered it off and re-did everything in stages and powered on again after each stage:So my ifi idsd suddenly wont work with my iphone, when i plug it in the LED indicator just turns white and the music plays on my iphone speakers.
Tried it with my friend's iphone and still same problem.
When I tried plugging it in my desktop pc and my laptop via the provided usb cable, the indicator led also turns white but it doesn't get detected by my desktop and laptop. Tried installing the ifi drivers but it gives the error "setup requires device is plugged in. please connect the device etc etc etc".
Everything else works btw, just the usb input.
Thanks!
