iFi audio GO blu - Super small. Super light. Super Sound.
- Thread starter iFi audio
Any advice on updating it, got the app installed etc but this is all I get and cannot select the blu as the tick box isn't selectable.
Is the Go Blu connected to your phone? It needs to be disconnected ~ then you can select GO blu on the app.
ledzep
Yeah it is, will try thanksIs the Go Blu connected to your phone? It needs to be disconnected ~ then you can select GO blu on the app.
ledzep
Disconnected it from phone and it's gone into pairing mode but still cannot select it
As someone else has suggested to me, make sure you have permitted the app to have full location access, not the partial, 'once when app is running' type.Disconnected it from phone and it's gone into pairing mode but still cannot select it
TooPoorForHiFi
Previously known as MidNighTempest
Two Questions
- Any issue when using the Go Blu as a Wired USB DAC/AMP for PC?
- Can you use the Go Blu as a "WIRED" Dongle with your Phone?
ledzep
Did the trick ! Many thanksAs someone else has suggested to me, make sure you have permitted the app to have full location access, not the partial, 'once when app is running' type.
hello,Two Questions
- no ( android, sony xperia 1 iii, uapp bit perfect)
- yes (but the cable is not included)
MartyMcfly3004
If you have an iPhone you will need to do the firmware update before wired works properly.Two Questions
soundblast75
- Nov 30, 2012
I can confirm it now works wired.If you have an iPhone you will need to do the firmware update before wired works properly.
The only problem remaining for iPhone is the maxing out of volume after pausing whatever media app you use and lock it.it goes back to max volume and it blows your eas
From the bottom of my heart, I really hope people will stop buying BT headphone adapter and believe it will turn out to be great USB headphone adapter / dongle for smartphone. It usually won't.
You should just buy a great USB headphone dongle instead if that's what you want.
Luckyleo
why do you hope so passionately? What happens if someone actually enjoys their BT headphone adapter and believe them to be great values? Why should you care? Really interested in your thoughts. Thanks!From the bottom of my heart, I really hope people will stop buying BT headphone adapter and believe it will turn out to be great USB headphone adapter / dongle for smartphone. It usually won't.
rlw6534
For me, a big part of it is the internal battery on these devices (BTR5, UP5, etc). When you disable charging, it doesn't drain your smartphone battery or cause errors on an iPhone (for too much power draw) in USB mode.
Hanesu
Any news when this is coming to Japan?
pk4425
The hip-dac or new hip-dac 2! I own a hip-dac -- fantastic USB headphone DAC-amp.From the bottom of my heart, I really hope people will stop buying BT headphone adapter and believe it will turn out to be great USB headphone adapter / dongle for smartphone. It usually won't.
