Please try various tips. I can change the sound a lot for different types of music with tips and how far the tip is pushed onto the nozzle.
Thank you for the suggestion. Actually Ive spent days doing this, even to the extent of A/Bing several different ones for several hours including the 3 stock tips, complys(not a fan on these, the insertion process is too long), noble red/grey silicone tips, sony hybrids, ttpod tips, and spinfits, and monster supertips. (there was even a failed attempt to use them with the Yamaha eph100sl tips).
Ive since settled on the Spinfits and the short cap wide nozzles as being my two favorites, however the spinfits insert deeper, improve the imaging a bit, and lessen the v-shape sound sig a bit as well. It even smooths out the treble a bit. Nothing mind blowing but the difference is there. Comfort goes to the stock tips.
Note: One thing that i did notice was that shallow insertion tips DO improve the soundstage, lessen the isolation, and lower the bass. By shallow insertion, i mean that the tip must fit on the iem so that the mesh is flush with the front of the tips. Usually this results in a need to use larger tips since they kind of just "cover the ear hole" instead of "plugging into" it. I've taken a set of the shallow insertion tips to work and ill be using it for the rest of the day to see what kind of changes they make. Caveat: since the IT03 seems to be designed as a deeper insertion iem and has very long nozzles, wearing the iem this way makes it so they dont sit flush in the ear. They only kind of just float in place, anchored by the shallow insertion tips.
[when i talk about changes to the sound I only mean about a 5-10% change, so take it with a grain of salt.]
The big thing though is that soundstage and depth did not really change. The z5 has this great ability to present the music about a couple inches in front of you and all around so it feels like the music is surrounding you, and although the IT03 is good at height and width, center imaging places the music just at the skin of my eyeballs, which is a bit more intimate than i would prefer. They also have a tendency to place the music higher a lot of the time. This means somtimes it sounds like the center imaging is coming from between my eyebrows. Actually, the center imaging is a little fuzzy, not as precise as I would like, but I AM comparing it to $700 Z5's. Who knows, the Sony's magnesium housing may actually be doing something to the sound P:
