dafos58
Something old & something new. Using the IT03 with the FiiO LC2.5D & Spinfit CP240. I never heard the IT03 sounding this beautiful
I'm ashamed to admit I still don't know how to get a picture right in a post. I'm getting to old........The image is broken for me, but thanks for sharing.
Vega works for me. very impactful bass but not bloated with clear highs. Using them with the Sony ZX300 which has thicker sounding notes to me. Sound stage is spot on with plenty of depth also.Hey everyone, I lost my it03 the other day and I am looking for an upgrade/sidegrade. The it03 is almost perfect for me, but the fit makes my ears ache, the bass is not as textured/impactful as I like, and the note weight I'd just a smidgen too light.
Does anyone have a recommendation for an item that has these qualities?
Slightly thicker/heavier note weight
More texture/impact with bass
Simpler fit
I am mostly a soundstage/bass head (quality bass, not quantity), if that helps. If there is a cable I can use that somehow helps with these things I'd consider getting the it03 again. I'm driving from a Galaxy S5 (I know, it's not ideal) but I have a couple OK quality sources at my disposal.
The JVC HA FDX1 was supposed to be my upgrade. Worst purchase I've ever made in audio. No bass, tinny highs, finnicky fit, shout mid, etc...
Reviving old thread.
I am in need of IT03 filter screen replacement, reached out to Paul but have not received a response so far.
Please let me know if anyone know where I can get replacement filter.
Just a quick update on the it03 upgrade...it isnt going well. Tried the h40 and while it had a brilliant soundstage I thought it was a significant downgrade in midrange and clarity in general. The instrument placement was poor as well. The FDX1 might have been a faulty pair as they have had QC issues I hear.
I am looking at purchasing the it03 again, but im also considering the mangird tea, mangird L3, and audiosense t800. If anyone has tried those let me know what you thought!
I am reaching out 3 years later because i am in a similar situation but can't find anything on AE so far.You'll find plenty in AE.
Any clue on how to get them to appear? search terms? Filter screen just shows filters for screens :]
