Jan 19, 2015 at 9:39 PM Post #76 of 109
I paid. $299.for it but real upgrade that it works flawlessly with my laptop,something MS was just not doing to we'll.Pops and clicks everywhere. I still have it though use it with my phone to connect it to my HU.
Is the noise/pops only on Windows machines ? OSX OK ?
Jan 19, 2015 at 10:54 PM Post #77 of 109
It was Windows 7 64bit,HRT will work with you though if there problems. I don't have any apple devices so don't know if there are problems with OSX as well.
Jan 20, 2015 at 12:21 AM Post #79 of 109
Excellent, may try and pick one up.....kind of off the Sabre style now...will sacrifice a bit of detail for musicality as that is the bottom line...listening to music vs analysis !
Jan 29, 2015 at 11:24 PM Post #80 of 109
Are there any older versions of this DAC that were a bit buggy etc ? I'm thinking of picking one up used vs new.
Also, does it work with USB 3.0 connections with no problem ?
Just thinking of any future upgrades of my OSX machine which is USB 2.0 just now and reading some USB DAC's having issues with USB 3.0.
Jan 30, 2015 at 3:34 AM Post #81 of 109
AFAIK, the only known bugs with this guy are with Windows machines and are fixable by update.
Jan 30, 2015 at 3:40 AM Post #82 of 109
it works with USB 3, I used mine on a USB3 hub, but it crashed though from time to time even when I hooked it up directly to the laptop.
Feb 1, 2015 at 11:03 PM Post #83 of 109
Hi, can anyone tell me the USB port type on the unit ?
USB female port but then it is one of the smaller USB plugs that insert into it...?
Feb 1, 2015 at 11:10 PM Post #84 of 109
USB mini
Feb 1, 2015 at 11:19 PM Post #85 of 109
  USB mini
Thanks.
Anyone know if it has some form of galvanic isolation built-in or should I use a USB noise isolator like Teradak clean 5V USB power to nudge things up a bit with power consistency/black background ?
This would work with porting the unit to external linear 5V power I think.
Feb 7, 2015 at 1:46 PM Post #86 of 109
Any guesses how good would HRT's new dSp / i-dSp Kickstarter project could be?. It looks like a variation of the microStreamer with just a headphone output. The specs:
Sample rate                                         up to 96 kHz (same as microStreamer)
Bit depth                                              up to 24 bit (same as microStreamer)
Full Scale output                                  1.75 Volts RMS (vs microStreamer = 1.4 Volts)
Output impedance                                .5 Ohm (same as microStreamer)
S/N Ratio (A-weighted)                         106 dB (vs microStreamer = 102 dB)
Noise floor (A-weighed)                         8 uV RMS (vs microStreamer = 18 uVolts)
Frequency Response (20 Hz / 20 kHz)   +0 dB / -.2 dB (vs microStreamer +0db / -.4dB)
Power requirements                             50 mA (vs microStreamer 100 mA)
Here's the link to the Kickstarter page:
http://www.kickstarter.com/projects/1698830754/dsp-making-your-headphones-sound-better
Feb 24, 2015 at 2:47 AM Post #87 of 109
Anyone running Fostex T50RP off the HRT MS ? Bass control OK or a bit lacking ?
Apr 8, 2015 at 6:03 AM Post #88 of 109
Anyone moving on up from their microstreamer give me a PM...Looking for one used !
Apr 11, 2015 at 7:27 PM Post #89 of 109
Possibly haha...
I asked this question in the other thread and want to ask it here too:
What do mS owners think would be a good upgrade? Anything under $400?
Needs to have:
- its own power supply (an obvious upgrade)
- USB async
- stereo RCA would be good
Apr 13, 2015 at 6:57 PM Post #90 of 109
  Possibly haha...
Needs to have:
- USB async
Are you using it as a dac/amp combo or just dac?
