Pianist
- Jan 3, 2007
Today, I had a chance to briefly compare RE0, RE272, FX700 and e-Q7 side by side. To my surprise, RE272 didn't fare quite as well against the other IEMs as I expected them to. I listened briefly to some pop and instrumental on my Clip and Sony players I used the same tips on all the IEMs to make the comparison reasonably fair. The RE0 pair I tested is over a year old and probably has over 1000 hours of burn in on them already. Same with e-Q7. The RE272 and FX700 are mine and have a lot less hours on them. FX700 has around 20-30, while RE272 has around 5-10. Not sure if that's what affected my impressions, but I suspect lack of burn in is not the problem here. At least I don't believe that headphone can change in sound that much with burn in. Yes, small changes are possible, but not huge differences IMO.
But anyway, here's what I found:
FX700 is clearly the least balanced signature of the 4 to my ears - they have a tad too much mid bass and treble emphasis compared to the others and also the bass sounds a bit slow and sloppy. I enjoyed them the least of the 4.
RE272 has the second worst balance for my tastes, although it is significantly better balanced than FX700 and a lot closer in balance to RE0 and e-Q7 than FX700. The problem with RE272 is that I find the sound a little too smooth, the bass lacking some kick, the highs sounding slightly peaky, although generally very smooth and the imaging and micro detail noticeably glossed over - not sharp enough IMO. I thought I could hear more detail with RE272 than with the others when I listened to just the RE272, but for some reason when AB'ing them against the others, I could not hear much if any extra information in my music.
RE0 sounded more balanced to me than the RE272 and as you are already aware when evaluating balance, I am not just considering frequency response, but the overall sound quality and character. The RE0 I tested had the foams inside the nozzles removed and yet it still it sounds darker than my RE272 which has the foams in. However, I found RE0 sharper, more defined sounding than the RE272 with similar or better extension both high and low and similar overall sound quality, at least when driven by such low-fi sources as the Clip. I understand that RE272 is supposed to be more revealing than RE0 and thus supposedly need a better source, but then RE0 is higher impedance, harder to driver and needs more power as well, so this comparison is only useful for those planning to use the IEMs mostly as portables with average consumer grade portable DAPs. Thus, I think RE0 is actually better suited for this application than the RE272 and provides a more fun and energetic sound than the latter without yielding to it in most other aspects of sound quality.
Finally, I found I enjoyed the e-Q7 the most out of the 4. With burn in, the highs on this IEM seem to get smoother and they have no trace of harshness that my newer e-Q7s used to have. I found that e-Q7 seemed to strike the best balance out of the 4 in terms of musicality vs. technical ability. It is fast, detailed, very lively, smooth and textured with excellent sense of space and good dynamics, but it also sounds sharper, better defined than RE272, much better balanced than FX700, more powerful than RE0.
Conclusion: A really unexpected one. It makes me feel like a fool for praising the RE272 too much. I think I will sell FX700 and RE272 and get the e-Q7 and RE0 again. The latter two simply suit my tastes with my sources better.
