HiFiMan Introduces New HE-500 Planar Magnetic Headphones
Aug 27, 2012 at 1:26 AM Post #1,756 of 1,779
I intend to rewire my stock HE-500 cable (silver) to XLR and build a "pigtail" for connection to a speaker amp (like the HE-6 cable). Does anyone know the correct pin allocations for the XLR? Am I correct in assuming that the conductor connected to the central pin in the earcup connector is positive, and should be connected to the red speaker output?
Finally, I assume that I should use the 8 Ohm taps rather than the 4 Ohm ones......
The speaker amp in question is an 18W PSE 300B Opera Consonance Reference 5.5 Mk.II (see avatar!)
I did the same thing - re-wiring the stock cable to XLR. Pinout is:
L+ pin 1
L- pin 2
R+ pin 3
R- pin 4
I just cut the 1/4" plug off then used a DMM to ID each wire. Yes, the central pin is positive on the earcup side.
Your amp has separate outputs for 4 vs 8 ohm? If so, I guess the higher one is more appropriate since the 500's are >> than 8 ohms.
Aug 27, 2012 at 10:04 AM Post #1,757 of 1,779
WNBC said:
Would people agree that bass control or tightness comes from both the headphone design and the amp driving the headphone? And if so, some amps might produce a tighter bass than others?
That is absolutely true
Aug 27, 2012 at 10:31 AM Post #1,758 of 1,779
In my experience, perception of bass control and tightness is more greatly affected by the fit/seal of the headphones to your head than it is from one amp to another. Just swap from velour to leather pads on the HE-500's and see what happens to the bass.
Aug 27, 2012 at 12:18 PM Post #1,759 of 1,779
Well,  If you swap amps with the same headphone you will see a difference if there is one.  I can say thin in my case:
LCD-2.2, HD650, and the Denon D7000.  these are the only so called bass heavy headphones I have.  My M^3 surly does give out more bass quantity.  However, My B22 surly does give out a better bass quality.  Meaning with the B22 I hear the bass being more tight and with more attack.  With the M^3 the bass sometimes bleeds over into the mids on these headphones and is less tight with a little more rumble.
Aug 27, 2012 at 3:29 PM Post #1,760 of 1,779
If you didn't do this under controlled conditions (blind, instant swtiching, level matched, etc.), then your experience, while valid for you, is inconclusive.
I do appreciate what you're saying and I'm glad you have found a subjective listening experience that sounds good to you though...
Aug 27, 2012 at 4:58 PM Post #1,761 of 1,779
Blind is always better - I agree 100% on that.  However, when you live with the amps the opinion then becomes un biased.  I'm not really sure it's inconclusive opposed to obvious.
I never do an instant switch.  IMHO you have to live with a sound before going to the next.  Then the different sounds become evident.
Nov 24, 2012 at 12:27 AM Post #1,763 of 1,779
Some edits: here are the 4 combos I'm still considering for the hifiman he-500
1. With musical fidelity m1 hpa
2. With schiit lyr
3. With violectric v100 or v200
4. With lake people g109
Anyone? (especially intrigued in 1.)
Nov 24, 2012 at 12:53 AM Post #1,764 of 1,779
2. With schiit lyr
Pairing with Bifrost + Lyr, love everything about it. + you can do tube rolling, with aftermarket cables, HE-500 just sing and bling~
Or, and that's what i am planning to do as well---> http://www.head-fi.org/t/629352/hifiman-he-500-on-a-speaker-amp-emotiva-mini-x-a-100-project
He-500 love the speaker amp~
Enjoy!
Jan 11, 2013 at 9:32 AM Post #1,765 of 1,779
Got a question here!
I am the somewhat new owner of the HE-500, and I am wondering about whether I play them too loud or not... Anyways!
With the 'phone lying next to you, playing music, how loud is it to you?? Is it like laptop speakers or a slight whisper?
Thank you
size]
Jan 11, 2013 at 10:23 AM Post #1,766 of 1,779
Laptop speaker
Jan 11, 2013 at 4:59 PM Post #1,768 of 1,779
That seems loud
size]
Usually I don't listen that loud, 10 'oclock on my 1.1 watt amp will do, 12 is like MAX, and that is speaker loud...
Jan 11, 2013 at 7:35 PM Post #1,769 of 1,779
I go to about 10-11 on my RPX-100 and that is laptop speaker loud
Feb 15, 2013 at 11:34 PM Post #1,770 of 1,779
Based on your description, likely not too loud for shorter periods of time, but probably a bit too loud for extended listening.
IMO, the BIGGEST way to improve audio quality is to eliminated background noise.
