JaZZ
So how exactly does x (soundstage size) become larger when the determining factor is reduced? 0dbfs crosstalk (that is 100% crosstalk) is mono. You can't honestly believe mono has a "brilliant soundstage".
Your mistake is to think that a maximized soundstage width is desirable, moreover one with an unnatural feature: extreme channel separation at low frequencies. When I'm talking of «preserved» of «improved» soundstage I'm addressing lifelikeness, credibility and threedimensionality. A hard-panned recording doesn't provide this, despite the wide soundstage. Note that it suffices to reduce channel separation at low frequencies, so you don't lose any essential spatial cues.
What are some things that RMAA do not test? Does it adequately test "quality of sound"? Or are we to believe the STX is the greatest thing since sliced bread? Mind you, I've seen results that put the STX at way lower than the advertised maximum of the dac chips it uses.
I don't understand your question concerning the «STX». An Asus soundcard? I can't speak for it. As to measuring sound quality: Without any extreme measuring data you can't predict the sonic characteristic or the sound quality of an electronics device. The only data I'd consider extreme with the HM-801 is the treble roll-off. Everything else is decent and below the established hearing threshold. Sound quality can effectively only be judged by ear.
